Vacuum Diagram
Old 07-15-2012, 04:55 PM
tinospony
tinospony's Avatar
Default Vacuum Diagram
does anyone has a GT vacuum diagram ... im looking for these lines...
the one that goes on the intake makes my car run rich ... i dont have smog pump ... i just need the most detailed diagram to see where else they go
thanks
not my car thou
tinospony is offline
Old 07-15-2012, 05:03 PM
mattdel
mattdel's Avatar
green goes to egr solenoid, red goes to air injection solenoids, not sure about the whites
mattdel is offline
Old 07-15-2012, 05:29 PM
ALMOST STOCK
ALMOST STOCK's Avatar
There should be Red, Green, Black and White
Red: to back of intake vacuum.
Green: to EGR
Black: to Air Bypass valve
White: to Air Diverter Valve
ALMOST STOCK is offline
Old 07-15-2012, 06:07 PM
If you dont have the smog pump you can plug off the white and tan colered ones. The red goes to feed the egr vacuum solenoid and also splits off to feed the air pump solenoids. the green is the return signal to the egr valve. The white and tan ones are the return signal to the smog pump valves. If you dont have the egr or the smog pump you can leave em all unplugged and just cap off where the red one goes to the intake as it is just a feed for all the others.
Old 07-17-2012, 02:24 PM
tinospony
tinospony's Avatar
thanks ppl!
Old 07-17-2012, 02:29 PM
tinospony
tinospony's Avatar
Green: to EGR
nice fox by d way
Old 07-18-2012, 10:24 AM
ALMOST STOCK
Originally Posted by tinospony
nice fox by d way
Thank you..
Old 07-23-2013, 01:24 AM
Doug Lizar
Doug Lizar's Avatar
can anyone tell me if the map sensor is supposed to have vacumn going to it and if so where does the vacumn come from????? 5.0 is running real rich....
Doug Lizar is offline
Old 07-23-2013, 04:37 AM
There is a speed density section for cars equipped with map sensors,
but , Yes the map sensor does have vacuum . It is direct from the manifold upper intake .
Old 07-23-2013, 06:59 AM
ALMOST STOCK
The vacuum line for the MAP sensor comes from here.
Quick Reply: Vacuum Diagram
