Leaving the top starter bolt out?
Old 07-24-2012, 09:55 AM
Lackey'sGT
Lackey'sGT's Avatar
Default Leaving the top starter bolt out?
Has anyone left the top starter bolt out of their car, or would it cause any problems? Mine is in the car now and I replaced my clutch over a month ago and it was a pain to get back in. I’m now going to replace my motor mounts and heard that you need to remove the starter. The top bolt took forever to get out and put back in and that’s the only part of the install I’m dreading so do you really need that bolt in there? Thank you.
Lackey'sGT is offline
Old 07-24-2012, 09:57 AM
1998Slow 'Stang
1998Slow 'Stang's Avatar
It's not bad if you go through the motor mount with a foot or so of extensions....it worked for me anyway.
I wouldn't leave it out, that's just lazy lol
1998Slow 'Stang is offline
Old 07-24-2012, 10:32 AM
madjimmax
madjimmax's Avatar
I use a 24 inch extension with a swivel type socket, this will have the ratchet in front of the motor where you have plenty of room to do what you need to do. But as said earlier dont leave it out.
madjimmax is offline
Old 07-24-2012, 10:39 AM
justinschmidt1
justinschmidt1's Avatar
Lots of people leave it out with no problems just FYI
justinschmidt1 is offline
Old 07-24-2012, 01:03 PM
uberstang1
Chupacabra
uberstang1's Avatar
I only have two starter bolts in mine, one of the lower threads on the trans is stripped out. Been fine for years.
uberstang1 is offline
Old 07-24-2012, 01:49 PM
JC316
JC316's Avatar
I have gotten so good that I can get it out in about 5 minutes, but I still leave the SOB out.
JC316 is offline
Old 07-24-2012, 02:13 PM
justinschmidt1
I can get to it easily with a tubular K member, but before that I just left it out for years, no problems.
Old 07-24-2012, 06:40 PM
disposablehero27
disposablehero27's Avatar
it is a pain no doubt, i too used the 90feet of extensions from the front of the motor. worked
disposablehero27 is offline
Old 07-25-2012, 07:30 AM
Lackey'sGT
Lackey'sGT's Avatar
Thanks guys for the responses, I think if I can't get it back in then I'll just leave it out but I'll try.
mtgldr
02-03-2024 09:00 PM
Tivo304
08-28-2023 12:19 PM
maestro1024
09-21-2015 02:40 PM
09-16-2015 03:07 PM
Quick Reply: Leaving the top starter bolt out?
