Instrument Dash Lights Won't Work
Old 07-27-2012, 10:12 AM
Chortdakooba
Chortdakooba's Avatar
Default Instrument Dash Lights Won't Work
The dash lights in my 79 Pace Car will not work. All the other guages, oil pressure, temp etc work fine.
I put in a new headlight switch that did not cure the problem. I also went through all the fuses and found that the slot for the cluster illumination had a 15 amp fuse when it should have been a 5 amp fuse. I switched to a 5 amp as per the handbook. I then pulled the cluster and checked the bulbs as I thought maybe they burned out, but they are fine.
As well, my dome light will not come on when you open the doors, but it will come on when you turn the headlight switch all the way left. I don't know if this problem would be related to the cluster problem or not.
Does anyone have any other ideas or had similar problems?
Chortdakooba is offline
Old 07-27-2012, 10:38 AM
javila2468
javila2468's Avatar
check your dim switch...could be faulty.
javila2468 is offline
Old 07-27-2012, 10:58 AM
Chortdakooba
Is there a way to test the dimmer switch? It does switch the lights from low to high and back, so I didn't think that could be the problem.
Old 07-27-2012, 02:17 PM
Big_Bertha_87
Big_Bertha_87's Avatar
Same thing with mine. I have to have the dimmer switch at a certain location in order to have lighting in the console.
Big_Bertha_87 is offline
Old 07-27-2012, 04:14 PM
Chortdakooba
Thanks for information. I have a new dimmer switch on order and will put it in tomorrow. Although all the cluster bulbs looked fine, I put all new ones in as well.
New dimmer switch, new bulbs and new headlight switch. Hope this all works.
Old 07-27-2012, 04:19 PM
ALMOST STOCK
ALMOST STOCK's Avatar
If your dimmer is one of the old style aluminum case units then you need to set the meter to a low resistance (ohms) scale and probe across the two silver colored terminals. While holding the probes across the terminals turn the dimmer **** and watch the meter. It should be a fairly smooth increase/decrease in resistance without any 'drop outs' in the reading.
If you have the newer plastic case switch then you probe across terminals R & 1. The identifiers are molded into the case next to each terminal.
To trace for power follow the circuit diagram and check for voltage along the dimmer switch circuit. Take the negative probe and connect it to a metal chassis part/screw and take the red lead and probe the connection points along the circuit. The BR wire behind the main light switch that goes to the back of the dimmer is a good place to start. With the main light switch in the Park position you should have about 12v at both points
ALMOST STOCK is offline
Old 07-28-2012, 04:26 PM
Chortdakooba
Well the new dimmer switch didn't work, in fact things got worse. The lights wouldn't even come on. I put the old dimmer switch back on the lights work.
I turned to testing the headlight switch. I noticed pin "A" in the wiring harness doesn't have a wire running into it. One of my tests is to test 12V running to A but there isn't even a wire there. That seems strange as it looks all stock.
Old 07-28-2012, 10:11 PM
Tony71502
Tony71502's Avatar
Have you taken your dash off before? My vote is a pinched wire causing a short.
Tony71502 is offline
Old 07-29-2012, 10:54 AM
Chortdakooba
Yes, I have taken the dash off and the instrument cluster, but I didn't see any crimped wires.
Right now I'm trying to find a diagram of the wiring harness for the headlight switch to compare to what I have.
Old 07-30-2012, 10:25 PM
ALMOST STOCK
This is the complete wiring diagram for 79
http://www.mc-machine.com/pdf/1979.pdf
Quick Reply: Instrument Dash Lights Won't Work
