Distributor Install
Old 09-21-2012, 04:48 PM
Duncan_GT
Duncan_GT's Avatar
Default Distributor Install
I'm just full of questions this week. I'm installing an MSD dizzy. I made the actual distributor housing flush w the front of the block (so the msd logo isnt crooked), i figured I would time from there when I'm ready. The rotor is supposed to point towards the #1 terminal, I know. However, no matter how I rotate the oil pump shaft I cannot get this damn thing to line up. Why won't it line up?
Duncan_GT is offline
Old 09-21-2012, 05:15 PM
javila2468
javila2468's Avatar
what doesn't line? the rotor to the #1 position on the cap?
javila2468 is offline
Old 09-21-2012, 05:17 PM
Duncan_GT
Duncan_GT's Avatar
Yeah. Its just barely passed it.
Old 09-21-2012, 05:18 PM
exactly whee is it falling ? Are you sure your at TDC on the #1?
It can sometimes be tricky to get the exact tooth you need to be at the #1 position.
If you know for sure your tdc compression then just keep at it somtimes you have to turn the roter a bit while your lowering it in.
Old 09-21-2012, 05:19 PM
javila2468
javila2468's Avatar
take out the distributor, stick a screw driver in #1 spark plug hole (just enough to feel the piston) and crank engine by hand until the piston hits the screw driver and back out just enough to remove the screw driver and restab it.
Old 09-21-2012, 05:40 PM
Duncan_GT
Duncan_GT's Avatar
It should be right on the 1 terminal correct?
Old 09-21-2012, 05:41 PM
javila2468
javila2468's Avatar
it'll slightly off...mine wasn't exactly on the terminal and it fired up.
Old 09-21-2012, 06:09 PM
Duncan_GT
Duncan_GT's Avatar
Its hard to take a pic to show it. Its maybe an 1/8" past the terminal
Old 09-23-2012, 04:34 PM
javila2468
javila2468's Avatar
U should be good with being 1/8th off. Stab it and give it a try
Old 09-23-2012, 08:00 PM
nitrous_bob
nitrous_bob's Avatar
i didnt read all of this..but i can already say STOP !!!!!
did you rotate the motor at all ? if yes
you need to re find TDC on the COMPRESSION stroke
so on #1 plug hole...rotate til it "phooshes" and stop your at TDC , install the dizzy and time it after you install it
it wont sit perfect...it is what it is
nitrous_bob is offline
Quick Reply: Distributor Install
