Convertible Top Oil/Grease Stains?
Old 10-24-2012, 02:32 PM
Ivan The Terrible
Ivan The Terrible's Avatar
Default Convertible Top Oil/Grease Stains?
I picked up a used 2011 V6 convertible a month ago and have noticed what appear to be two small stains on the convertible top caused by oil or grease soaking up through the top coming from the convertible top hardware. The stains are about the size of a nickle or quarter and are located on the third ridge from the back on both sides of the car nearest to the convertible top seam that runs along the length of the car. The hotter the temperature outside the more you can tell that the stains are caused by oil or grease as the substance becomes more liquid from the heat and you can feel it on your finger if you touch the spots. Can anybody verify my suspicion that this is caused by lubricant coming from the convertible top hardware?
I have added links to pictures:
https://mustangforums.com/forum/memb...9-stain-1.html
https://mustangforums.com/forum/memb...0-stain-2.html
Ivan The Terrible is offline
Old 10-24-2012, 02:43 PM
AMWill
Former Sponsor
AMWill's Avatar
I haven't heard of anyone having this problem before with their convert tops. I'm interested to see what you find out. Hopefully another member will be able to join in and share their experience.
Best of luck!
Shane
AMWill is offline
Old 05-23-2013, 10:37 AM
Richwood55
Richwood55's Avatar
I have a 2011 V6 convertible with the same problem. I'm going to check with the dealer
Richwood55 is offline
Old 05-23-2013, 12:27 PM
Roy_R
Roy_R's Avatar
Sorry to hear about your problem....but I got distracted by this....
https://mustangforums.com/forum/memb...0&ref=gnr-prev
Roy_R is offline
Old 05-23-2013, 12:56 PM
Doogie65
Doogie65's Avatar
Being an '11, it should be still under warranty, correct?? Definitely take in if that is case. I even had my top replaced under warranty due to excessive wear from the heavy creases with the original cloth top design.
Doogie65 is offline
Old 05-24-2013, 07:44 AM
Tommyc
Tommyc's Avatar
I've had 3 GT converts in a row over the last 14 years, never seen that. Its got to be from the hardware. Its easy enough to clean up if ford gives you trouble.
Tommyc is offline
Old 05-24-2013, 02:13 PM
BrazenStang
BrazenStang's Avatar
It is less likely to be grease and oil actually soaking through the top. It would leak water if that was the case. It could be from where the top gets tucked away behind the rear seat. Feel around and try to see if there is dirt and grime build up back there. find exactly where the stained portion is sitting behind the seat and look for the dirt in that area. Some dawn dish soap and a brush should take care of the stain. then use some protecting after you clean it.
Posted from MustangForums.com App for Android
BrazenStang is offline
Old 05-24-2013, 03:12 PM
Ivan The Terrible
What did the dealer tell you Richwood55?
Last edited by Ivan The Terrible; 05-24-2013 at 03:14 PM. Reason: Forgot to quote message
Old 05-24-2013, 03:16 PM
Ivan The Terrible
After looking at that post I forgot I even made this thread LOL!
Old 05-24-2013, 03:18 PM
Ivan The Terrible
I will check if that's the cause of the problem this weekend...thanks.
chrisdbassplayer
10-13-2015 06:53 PM
b8checker
09-30-2015 07:11 AM
treesloth
09-28-2015 07:03 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: Convertible Top Oil/Grease Stains?
