NEW! DivisionX 99-04 Mustang Fuel Rail Pressure Sensor Adapter! IN STOCK
New From DivisionX! DivisionX 99-04 Mustang Fuel Rail Pressure Sensor Adapter
Finally! An adapter that will allow you to still retain the Ford Factory fuel rail pressure sensor!
DivisionX has finally developed an adapter that can now be utilized with DivisionX, and most aftermarket fuel rails that use a -8 O-Ring fitting (see images below)
You can also use this adapter with our Lethal Performance 99-04 4V Budget Return Style Fuel System & Lethal Performance 99-04 2V Budget Return Style Fuel Systems with utilization through through the provided DX Regulator in the budget kits.
The adapter comes with a Viton O-ring and M5 bolts for simple installation.
Visit Lethal Performance.com or give us a call @ 1-877-2LETHAL
