any ideas about squeaking noise?
Old 02-17-2013, 06:24 AM
1st_time_mustang
1st_time_mustang's Avatar
Default any ideas about squeaking noise?
i just bought a 1996 mustang GT convertible with 93k miles on it. when driving down the road I hear at periodic squeak squeak squeak. the sound goes away when I lightly tap and hold brakes on. My guess is I need new rear brake rotors
1st_time_mustang is offline
Old 02-17-2013, 06:26 AM
1st_time_mustang
sorry I mean new brake pads I just woke up :-)
Old 02-17-2013, 08:44 AM
blu30val
blu30val's Avatar
Usually when the wear indicator starts contacting the rotor, it will do exactly what you described. Better sooner than later, take a look at your pads before throwing parts at it, if possible mic your rotors at the same time. Also check your bearings. On a few rare occasions I've had the symptom your describing at work, and found a bearing being the root cause. Are you doing your own work?
blu30val is offline
Old 02-17-2013, 11:42 AM
2001Supercharged GT
2001Supercharged GT's Avatar
^+1 It is most likely the brake pads but look at them before you go out and buy parts only to find it's not the issue.
2001Supercharged GT is offline
Old 02-19-2013, 12:43 AM
Jango1201
Jango1201's Avatar
Ohhh welcome to my world. I've the problem for over a year and just got rid of it. I replaced pads, rotors, calipers and it still kept coming back. Found out last week the problem was my axel bearings! I changed them out and haven't heard that squeak since.
Jango1201 is offline
Old 02-24-2013, 05:37 AM
1st_time_mustang
thanks everyone I've got some new pads and a wheel bearing ready to go once I get it back from body shop. I am having the front bumper repainted. i should have it back early to mid week. I got it in the shop before snow storm Q hit
Old 03-02-2013, 06:31 PM
Fordman2011
Fordman2011's Avatar
I know this thread is a week old but i was having the same issue so i took everything off and noticed that i didnt have any pad retaining clips. Went and bought some and havent had the problem since. Hope this helps a little.
Fordman2011 is offline
Old 03-03-2013, 05:09 AM
1st_time_mustang
my 96 GT has been in the body shop for a week getting the hood and front bumper repainted. i should have it back mar 5th or 6th. The owner of the small shop is 71 and had eye surgery (cataract removed) Mar 1st. after i get it back I can start diagnosing.
I have some new brake pads and a new rear wheel bearing and seal ready to install
Old 03-07-2013, 09:54 PM
blu30val
blu30val's Avatar
Any luck with your brakes?
blu30val is offline
Old 03-10-2013, 09:49 AM
1st_time_mustang
not yet, my stang is still in the body shop...the paint guy didn't like his paint job.on the hood so is redoing it. tis just as well with the snow and rain we've had all week. maybe i will get it monday mar 10th
Quick Reply: any ideas about squeaking noise?
