Hand Brake
Old 03-08-2013, 10:52 AM
BeastMachine67
BeastMachine67's Avatar
Default Hand Brake
Hey guys I got a problem with my hand brake and I was hoping someone could give me some good tips on how to fix it or what to check. I bought my 05 gt used and I don't know if the previous owner abused the car or what but, sometimes when I pull the hand brake up the car still tends to roll back a bit. Now, I've already tried tightening the adjustment nut located in the center console behind the hand brake but, all that seems to do is make the lever stiffer and harder to pull up. Does anyone know what else I can check or do??
Thanks
BeastMachine67 is offline
Old 03-11-2013, 07:29 AM
Buchez09GT
Buchez09GT's Avatar
I'm not 100% sure if they have these but; have you tried looking at the brake shoes?
Buchez09GT is offline
Old 03-11-2013, 02:13 PM
krazykevin
krazykevin's Avatar
Im not sure about the mustang, but you can try putting the parking brake on tight, and then put it in reverse and back up 15 feet. This is the built in way to tighten most hand brakes. If this does not work, then you will probably have to adjust it at the wheel. Let me know if this works.
krazykevin is offline
Old 07-22-2013, 11:01 AM
BeastMachine67
it doesn't look like it worked
Old 07-22-2013, 11:30 AM
AzPete
AzPete's Avatar
Some have cars had problems with corrosion in winter areas. The cables would get wet, freeze over night, and the moisture never really dried out for some time due to weather. The corrosion would cause the cables to bind. The old fix from Ford was new cables that had better weather protection. Yours could have this leftover issue.
AzPete is offline
Old 07-22-2013, 11:40 AM
calistang05
calistang05's Avatar
Yeah that's what happen to my 05 GT the cable was all twisted up which made it hard to pull up and to release it down. It would barely go all the way up to much tension.
calistang05 is offline
Old 07-22-2013, 12:13 PM
S stang
S stang's Avatar
On my 06gt on the trans. Tunnel their is a cable adjusment plate wear the cable. From the hand break meets the two rear cable and can be adj. a good spray of wd40 on all the cables will help too
S stang is offline
Old 07-23-2013, 11:53 AM
BeastMachine67
Im not sure if the cold weather would be an issue since I live in southern cali.
but, S Stang I'll look for that plate you're talking about next time Im under there
Old 07-23-2013, 04:34 PM
AzPete
AzPete's Avatar
Rain can still cause the cables to corrode....worth checking while under the car.
AzPete is offline
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Hand Brake
