engine bore question
Old 04-16-2013, 09:13 PM
samltheriault
samltheriault's Avatar
Question engine bore question
does any one know what the general price range it is to bore a 5.0 boss block 30 over??? big change in plans. going to a 363ci but trying to get my budget together
samltheriault is offline
Old 04-16-2013, 09:41 PM
Duncan_GT
Duncan_GT's Avatar
Mine was $15/cylinder = $120
Duncan_GT is offline
Old 04-16-2013, 10:05 PM
samltheriault
NOOOOO SHIIIITTT 8D so stoked. haha alright well i got all my parts together. not so sure if they would fit together well but i think i got it nailed pretty good. ill post the links if you or any one wants to take a quick look. bare with me this is my first engine build so i help is much appritiated
pistons
http://www.jegs.com/i/Mahle/644/SBF090030I16/10001/-1
crank
http://www.jegs.com/i/Scat/942/43023-2/10002/-1
h beam conecting rods. not sure the advantages /disadvantages they have over i beam. gonna b boosted pretty soon nad not sure what handles big psi better.
http://www.jegs.com/i/Scat/942/65400927/10002/-1
block
http://www.jegs.com/i/Ford-Racing/39...SS302/10002/-1
ik it may take a while but if any one wants to look through it and give me pointers that would be greatly appreciated. as stated before. this is my first engine build. and if going ham as you can see haha
Old 04-16-2013, 10:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
not a smart idea to do a 363 in a boss block with the short skirts, you really need to speak with Jim Woods at fordstrokers.com ABOUT THE ISSUES SUCH PRESENTS.....or don't it's your money
mjr46 is offline
Old 04-16-2013, 11:23 PM
Duncan_GT
Duncan_GT's Avatar
I would look at the shp dart block. You'll need to spec out piston rings and all bearings also. Might save you some headache to look for a stroker kit instead of piecing your own. Theyre usually discounted a little bit as well.
If you're getting a brand new block, you'll have to do all of the machining to it, not just the bore. Add in cam bearings and freeze plugs also
Old 04-17-2013, 01:41 AM
tinman
tinman's Avatar
Overbore/hone jobs range anywhere from $10-$50 per cylinder depending on who does it.
Is the block one of the newest ones from Ford or an older one?
The newer ones are cast somewhat different than the first ones were.
I'd plan on the overbore/hone, align bore as well as checking/decking the block to get the pistons about .010 down in the bore.
You'll also need to get the stroker kit balanced.
Last block I had done was close to $700 for the machine work and about $200 for balancing........
tinman is offline
Old 04-17-2013, 04:33 AM
GTnotchback
GTnotchback's Avatar
All machining, bore etc on my boss block was $800. Brand new block like u are doing.
GTnotchback is offline
Old 04-17-2013, 09:55 AM
Duncan_GT
Duncan_GT's Avatar
I forgot about balancing ^^^. Mine was internal, so add in $400. All of that, plus i had my heads milled and my lower intake port matched
Old 04-17-2013, 03:26 PM
samltheriault
ehh **** it im gonna look into the dart performance 363 stroker. the only thing is im looking for around 9-1 compresion so i can run a turbo in the near future. instead ill just do a 347 cause i can get all the power i want out of that. this should do just fine. just bolt on and go from there
http://www.jegs.com/i/Dart/301/03213...86#moreDetails
Old 04-17-2013, 04:35 PM
Duncan_GT
Duncan_GT's Avatar
If you get a short block, i would still disassemble it and check everything unless its built for a reputable shop
Quick Reply: engine bore question
