Going from 6 bolt to 8 bolt clutch
Old 04-17-2013, 12:00 PM
Ablaze
Ablaze's Avatar
Default Going from 6 bolt to 8 bolt clutch
Do you need a WHOLE new clutch to go from 6 bolt to 8 bolt? Say you had a McLeod RXT running on a 6060 and you later install a forged shortblock with an 8 bolt crank. Can I just make an exchange or do I need an entirely new clutch??
Ablaze is offline
Old 04-17-2013, 01:05 PM
danzcool
danzcool's Avatar
No. you don't need a whole new clutch.
You may need new clutch disks depending on how much wear or if the flywheel is a different size.
danzcool is offline
Old 04-17-2013, 01:26 PM
Ablaze
Ablaze's Avatar
What part would I buy to make the swap? Do I just go to the vendor and ask for the 'upgrade'?
Ablaze is offline
Old 04-17-2013, 02:48 PM
danzcool
danzcool's Avatar
you might not need anything, depending on wear. But just call mcleod and ask.
danzcool is offline
Old 04-18-2013, 03:45 AM
07 GT E UPP
07 GT E UPP's Avatar
Yep, whole new clutch/flywheel for me !
07 GT E UPP is offline
Old 04-18-2013, 03:56 AM
danzcool
danzcool's Avatar
In my case, I installed the 25 spline rxt clutch along with a mcleod 6-bolt aluminum flywheel when I upgraded to the t56 magnum xl transmission 13 months ago. I just swapped to a forged block and went with a mcleod 8-bolt steel flywheel, and did nothing with the rest of the clutch.
danzcool is offline
Old 04-18-2013, 09:09 PM
bigstick
bigstick's Avatar
Me too. Except I went with an Exedy 8-bolt steel f/w.
bigstick is offline
Old 04-19-2013, 11:56 AM
Simon1
Simon1's Avatar
You just need adifferent flywheel.
Simon1 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Going from 6 bolt to 8 bolt clutch
