DIY 1969 Hydraulic clutch pictures and ideas to build a kit on early T5 transmision
Old 04-19-2013, 09:11 AM
juit
juit's Avatar
Post DIY 1969 Hydraulic clutch pictures and ideas to build a kit on early T5 transmision
I paid for all of this 170 bucks so its a big saving
got an incredible deal from High Performance Parts & Accessories - Car Shop Inc. and sold me this combo
I've bought so far:
wilwood hydraulic master
cnc slave 7/8
clutch line
I just made this L bracket 2x2 outside
firewall reinforcements plate installed with pedal
engine looks
I drilled and taped for 3/8 screws Im planing to S.S. helicoil them in the future
heim joint in ebay for 3 usd http://www.ebay.com/itm/ECON-5-16-x-5-16-24-FEMALE-RH-ROD-END-HEIM-JOINTS-HEIMS-/390437762617?pt=Motors_Car_Truck_Parts_Accessories&hash=item5ae7e77639&vxp=mtr http://www.ebay.com/itm/ECON-3-8-x-3-8-24-FEMALE-RH-ROD-ENDS-HEIM-JOINTS-HEIMS-/370613770292?pt=Race_Car_Parts&hash=item564a4d5834&vxp=mtr
I was amazed what SELLERSRODSHOP did but I dont have the welding skills and he got some problems later on becaus the master cylinder was offset
changing that linkage out to heim joints should smooth things out a good bit. as far as the hydraulic setup, i cant help with the pull slave, but i've made a few of these master setups for guys & am installing one on my car right now (c4/t5 swap) . this is a CNC master, recommended on several sites, mounted in the original hole with good clearance around the stock booster.
inside, i made this bracket that wraps around & bolts thru the clutch pedal & aligns with the pushrod on the cnc via a heim joint:
heres a cross section view. helps to have a spare firewall section to set everything up with
juit is offline
Old 04-19-2013, 09:12 AM
juit
juit's Avatar
I bended the yellow stud a lil to make a soft swing
If you can see I also hooked to the wheel firewall screw
with this the clutch wont move the firewall
here is a video link with an awful ending
t5 clutch bracket mustang 1969 69 - YouTube
BEWARE IF YOU HAVE KIDS OR HAVE A HEART PROBLEM DONT LOOK AT THE VIDEO YOU HAVE BEEN WARNED
juit is offline
Old 04-19-2013, 09:44 AM
MonsterBilly
MonsterBilly's Avatar
Juit, with all do respect to your work, it is going to fail. I know because I did the same thing. eventually the master will wear because of the wrong angle and the stress on the plunger. then, it will break either the steel bar you have going from the pedal to the rod or it will snap the hiem joint.
I only say this, not to ctritcise your work but to make sure that you are not sitting at a stop light when it does. Your car will lung forward and hit the car in front of you.
I know this because I did almost exactly what you did and mine broke. It took about a year though.
Good luck my friend.
MonsterBilly is offline
Old 04-19-2013, 12:41 PM
juit
juit's Avatar
thanks bro but its been runing for more than a year I even took it ot on the last pics for inspection
Ill keep an eye on this, thanks for the heads up
I think the pedal that I have is not a normal one, it has holes in different places
thats how I got the car maybe it was modded by prev owner who knows
juit is offline
MaKaVeLi
06-26-2010 05:05 PM
tom75a
04-02-2010 04:32 PM
joe_5.0
05-15-2008 01:37 PM
luizGT91
4 Cylinder NA and Turbo
02-01-2007 05:18 PM
95hooptey
06-25-2006 05:18 PM
Quick Reply: DIY 1969 Hydraulic clutch pictures and ideas to build a kit on early T5 transmision
