drilling into carbon fiber
Old 04-24-2013, 12:06 AM
blacknred93
blacknred93's Avatar
Default drilling into carbon fiber
how would i go about drilling holes for hood pins in a carbon fiber hood? its made by VIS for a fox body if that makes any difference
blacknred93 is offline
Old 04-24-2013, 12:43 AM
SyNdicateZ
SyNdicateZ's Avatar
It's easy to drill through it. Install hood pins. Put marshmallow fluff on the tips of the pins. Lower hood onto pins, this way your leave fluff on the hood where you need to drill. Make sure u drill sorta at an angle from the bottom of hood. Start with a smaller sized bit. you'll get it. I also have a ViS hood..with frpp pins
SyNdicateZ is offline
Old 04-24-2013, 12:12 PM
blacknred93
Thanks that fluff idea is genius. I need a special bit though dont i?
Old 04-24-2013, 10:24 PM
tinman
tinman's Avatar
I've been using non-drying Prussian blue (or red) to make hoods and other panels for years.
Grianger sells it..........
tinman is offline
Old 04-25-2013, 11:45 AM
blacknred93
Thanks but im not fabricating the hood or anything. I already the vis hood it juat disnt come drilled out for hood pins
jwog666
12-27-2021 08:09 PM
svfetter
10-05-2015 11:39 AM
mdg
10-01-2015 07:04 AM
GLOCKer
09-28-2015 07:36 AM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: drilling into carbon fiber
