Help!Tranny Fluid Leaks to half capacity, all over bellhousing
Old 04-24-2013, 12:49 AM
MacSerio
MacSerio's Avatar
Default Help!Tranny Fluid Leaks to half capacity, all over bellhousing
1991 mustang gt manual i checked tranny fluid after hearing whine and feeling roughness in tranny and it was only half full and leaking everywhere, but not leaking on ground, just underneath car. I'm also missing two bolts that connect tranny to bellhousing, can this cause a leak? please help me out and ask me for any info to help us figure this out. THANK YOU!!!
MacSerio is offline
Old 04-24-2013, 03:25 AM
Missing 2 of the bolts that hold the trans to the bell housing could have caused the trans to crack. Did you loose the bolts ? It wasn't a good Idea to install the trans like that considering there is only 4 bolts that hold it to the bell housing on a t5 .
Old 04-24-2013, 07:18 AM
MacSerio
MacSerio's Avatar
well now i see im missing three bolts, dam .
i didnt notice when i bought it and idk how long its been like this but this is where i see most of the fluid at, can fluid leak out of here? Not familiar with trannys yet.....
so before i install bolts and fill with fluid i wanted to know if this is my likely cause of leak.
MacSerio is offline
Old 04-24-2013, 07:26 AM
WOW its missing 3 of the 4 bolts that hold the trans to the bell housing?? I would pull it and examine it carefully for cracks. Im surprised the trans is even still in the car.
Old 04-24-2013, 07:32 AM
MacSerio
MacSerio's Avatar
i know i know but, my question....
can fluid leak out of here?- where the tranny meets the bellhousing
MacSerio is offline
Old 04-24-2013, 07:36 AM
Not from just missing bolts , It likely destroyed the input shaft seal or worse.... there is no gasket between the bell housing and tran
Old 04-24-2013, 07:40 AM
MacSerio
MacSerio's Avatar
right right well i see a gasket between them but obviously the connection is loose; so does the tranny fluid fill all the way to the bellhousing? i guess thats what the gaskets for, right? just dont wanna drop it if i dont have to, for different reasons....
MacSerio is offline
Old 04-24-2013, 07:55 AM
That gasket you see there is not for a sealing purpose. Fluid is only present in the gear box of the trans . There is a gasket behind the input shaft retainer and a seal around the input shaft. If you have fluid leaking out between the bell housing and gear box then there is a problem with either the input shaft seal , the input shaft retainer gasket or the trans has a crack in it. All 3 need the trans out to examine.
Replacing the 3 bolt will have no effect on fluid leaking.
Old 04-24-2013, 08:04 AM
Here is a pic of the front of the t5 with out the bell , Notice the input shaft retainer ring that is bolted around the input shaft . There is a gasket behind that and a seal around the shaft. Likely the trans was shifting and vibrating a lot and caused damage to the shaft seal , possibly even cracked the input shaft retainer. No fluid should be present in the bell housing , it stops behind that retainer. [IMG][/IMG]
Old 04-24-2013, 08:24 AM
here is another pic of the retainer and the shaft seal that most likely is failing....
[IMG][/IMG]
Quick Reply: Help!Tranny Fluid Leaks to half capacity, all over bellhousing
