Rats ate some of my harness :(
Old 04-24-2013, 12:55 AM
hawaiian-mustang
hawaiian-mustang's Avatar
Default Rats ate some of my harness :(
Hey all, so my in laws stock, 05 mustang(v6) has a cel due to bank 1 sensor 1 or sensor, I thought nothing and had them order the Parr and replaced it for them, well I turned the car and the same stupid code is their for the same exact part, closer examination and what do I see? The wiring for the passenger side of the of sensor wiring has been chewed up, the wires are still in tact but missing the shield. My problem is, I can't resplice it cuz theirs absolutely no room being that the top of the trans is behind the motor, below the firewall. Is it a pain to drop the whole harness to drop that portion of wiring down? Or am I screwed?
hawaiian-mustang is offline
Old 04-24-2013, 11:11 AM
157dB
Cut & Paste Expert
157dB's Avatar
http://iihs.net/fsm/?dir=40&viewfile...20-%204.0L.pdf
I would suspect that you will have to drop the tranny to access the wiring harness.
It goes directly to the PCM without going thru any connectors.
157dB is offline
Old 04-24-2013, 02:07 PM
hawaiian-mustang
Freaking heck..........ahhhhhhhhhhh. so no other possibility than huh?
Old 04-24-2013, 02:11 PM
Anything is possible but probable is another story
Unless you have nimble alien like fingers/hands and you can get into the area where the wires are, cut them, and then reconnect them, you're stuck having to drop the tranny to gain access.
The other thought is to see if you can find the wire at the PCM side, cut it few inches from the harness and then run your own length of wire to the O2 Sensor and reattaching the O2 harness at the other end thus bypassing the OEM wiring. Of course you should protect the new run of wire with wire loom just like the OEM.
Old 04-24-2013, 06:51 PM
hawaiian-mustang
I see, I'll try that and thanks for the info,jus to ask, where does the factory loom run from the of sensor in the engine bay?I know its already above the top of the front of the trans, any pics?
Old 04-26-2013, 10:09 AM
157dB
Cut & Paste Expert
157dB's Avatar
My printed workshop manual shows the harness and
location but the online manual does not....
So unless you have the printed workshop manual...
Attached Thumbnails Rats ate some of my harness :(-workshopmanuals.jpg
157dB is offline
Old 04-26-2013, 01:57 PM
2005Redfire6
2005Redfire6's Avatar
I was waiting for the manual to come out!
2005Redfire6 is offline
Old 04-26-2013, 02:46 PM
157dB
Cut & Paste Expert
157dB's Avatar
Been waiting long?
I got mine in 2007 when I bought my 2007 Mustang.
www.mustangsunlimited.com has them for sale and
has had them available for quite a while.
157dB is offline
Old 04-26-2013, 09:35 PM
hawaiian-mustang
Uggggh I can't view the pic or link u posted bro cuz I guess I'm new still so my account isn't letting me, could u tell me where to look for the Pcm and wiring diagram as to wat pin the bank 1 sensor 1 is for the o2,(that is the passenger side front of sensor right?
Old 04-27-2013, 10:52 AM
157dB
Cut & Paste Expert
157dB's Avatar
Look in the printed manual.
Its not new memmer probs cuz.
Its browser probs not letting you see the pdfs. (:
And alas that info is not on the online site.
Just the printed manuals.
www.mustangsunlimited.com for the electrical workshop book...
Cant sem to find it onlne.
http://www.mustangsunlimited.com/Sub...s=LMN15&grid=N
157dB is offline
Quick Reply: Rats ate some of my harness :(
