2006 Mustang GT rims and tires fit a 1965 Mustang?
Old 04-25-2013, 11:21 AM
Rustymopar
Rustymopar's Avatar
Default 2006 Mustang GT rims and tires fit a 1965 Mustang?
Will 2006 Mustang GT rims and tires fit a 1965 Mustang without any spacers or rubbing?
Rims and tire have around 60% of tread left on them and they are Pirelli P-Zero Nero 235/55/ZR17 tires
Cant upload a picture at work.. Will tonight..
Heres the link.
http://baltimore.craigslist.org/pts/3743176758.html
Rustymopar is offline
Old 04-25-2013, 12:30 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
no not without spacers...you will need about an inch and a half adapter
rmodel65 is offline
Old 04-25-2013, 07:01 PM
Rustymopar
Rustymopar's Avatar
I saw a post from 2009, which said they would fit without a spacer and no rub. Where does this spacer go? and does the front and rear both need a spacer?
Old 04-25-2013, 07:18 PM
Rustymopar
Rustymopar's Avatar
Of course I cant find the article now...
Old 04-25-2013, 07:23 PM
Rustymopar
Rustymopar's Avatar
Found it.. Seems the tire is the issue though... What are your thoughts?
https://mustangforums.com/forum/clas...6-mustang.html
Old 04-27-2013, 01:12 AM
tx65coupe
tx65coupe's Avatar
I don't see any mention of them not working with out spacers, except for maybe on the rear if the axle is wider. In which case, I would pass on them. If they won't fit without spacers, they don't belong on the car.
tx65coupe is offline
Old 04-27-2013, 01:06 PM
Iskwezm
Iskwezm's Avatar
the problem with the tires was a 55 series 17" is over 27" tall.if you were to use a 225/45/17 there shouldnt be any rubbing issues depending on the height of the car.
Iskwezm is offline
Old 04-28-2013, 01:56 PM
Rustymopar
Rustymopar's Avatar
Are they any modern Mustang Rims and tires which will work on a 65?
So essentially, its the tires size which is the issue?
Old 04-28-2013, 02:02 PM
Rustymopar
Rustymopar's Avatar
How about a 17" rims... 245/45 spacers still? If so,, What size?
Old 04-28-2013, 07:44 PM
Rustymopar
Rustymopar's Avatar
This is what I'm considering..
http://baltimore.craigslist.org/pts/3770775093.html
Quick Reply: 2006 Mustang GT rims and tires fit a 1965 Mustang?
