1991 Mustang Convertible Top won't go down
Old 04-25-2013, 12:17 PM
jnoback
jnoback's Avatar
Default 1991 Mustang Convertible Top won't go down
I have a 1991 5.0 Convertible Mustang and the top won't go down. When you push the button, it doesn't do anything. There is no noise of a motor running or anything else, only silence. I tried replacing the fuse and that didn't help. Any suggestions would be appreciated.1991 Mustang Convertible Top won't go down-mustang.jpg
jnoback is offline
Old 04-25-2013, 01:29 PM
I would go to the back and find the motor that operates the top and confirm that it is getting power when the switch is pressed. If it is getting power back there then chances are the motor is no good. If you get no power to the motor then the relay is probly not any good or you have a bad ground . Im not a vert guy but I have messed with some different models , they usually use an electric motor running a hydraulic pump. Ive seen the lines crack and loose all the fluid out of the pump then the motor turns but the top does nothing and some of the motors are so quiet you can only tell there running if you have someone hit the switch while your back at the motor listening.
Old 04-25-2013, 02:49 PM
BabyGT
BabyGT's Avatar
Emergency brake has to be up for the top to operate.
BabyGT is offline
Old 04-28-2013, 08:05 PM
dwb91lx
dwb91lx's Avatar
That's not true on mine (the E-brake)... My top will sometimes glitch when I stop it greater than or less than 1/2 way (when I'm tucking material or avoiding the scissor action on the material)....The trick that usually works is to manually lift the top while operating the switch...kinda like push starting. Avoid letting the frame settle (on it's own). If I need to stop it midway, it is always best to stop it straight up...or give it a helping hand to avoid the settling. It's happened plenty of times (10+) & I've always gotten it to work...knock on wood.
dwb91lx is offline
Old 04-28-2013, 08:43 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ive never had to manually do anything with my top...in fact the fox mustang was praised at the time for having a top that was as fast or faster than a benz vert when it came out...like said above you need to see if you are getting power...it might just be a bad top if it was running and not moving anything i would say its low on Auto trans fluid in the top motor.
rmodel65 is offline
Old 04-28-2013, 10:49 PM
craig71springsport
craig71springsport's Avatar
No juice to your top motor is my guess. Or the motor itself is bad, like others are saying just get a tester and test the lines going to it. I would check CL for the motor, they get pricey IIRC.
craig71springsport is offline
Old 04-29-2013, 08:04 AM
dwb91lx
dwb91lx's Avatar
always try the easy effort stuff first, motor diagnosis takes more effort & tear down...you'll want to remove back seat & trunk interior trim to get a good look @ the motor for fluid, relay checks, etc.
dwb91lx is offline
Old 04-29-2013, 09:37 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
iirc the top motor is the same from 1965-2004 so they are pretty easy to find. ive seen fox vert 4 cylinder cars for 400$ could always buy one of those and get the top motor and sell the hull for scrap=free top motor and any other parts switches, wiring etc you need
rmodel65 is offline
Old 04-29-2013, 10:23 AM
7 UP Mustang
7 UP Mustang's Avatar
MY 1990 LX has two relays, and one went out. The easy thing to do is to swap the relays around since they are plug in types. One is used for UP and one is used for DOWN. In my case a new relay fixed my problem. Good luck!
7 UP Mustang is offline
Old 04-29-2013, 04:58 PM
89StangGTConvertible
89StangGTConvertible's Avatar
Yep - check relays first, then pull back seat and see if you're getting juice to the motor when the switch is activated. Hoping it's just a bad relay. Good luck and post back when you find out what the issue was, as it may prove helpful to someone else who is experiencing the same issue.
89StangGTConvertible is offline
Quick Reply: 1991 Mustang Convertible Top won't go down
