Opinions On Decently Priced Brakes
Old 04-25-2013, 06:22 PM
cslix
cslix's Avatar
Default Opinions On Decently Priced Brakes
05 v6 looking to change front and rear rotors, pads, and maybe even calipers.
Found "Power Stop Kit" which includes below:
1-Click; Incl. OE Replacement Rotors w/Z16 Ceramic Scorched Pads
link:
http://www.rockauto.com/catalog/more...028&cc=1431309
The above Brakes come to about $208.00 USD including shipping..
Any suggestions on brake pads and rotors? Maybe I should by the rotors and pads separably and not in a kit? Also i heard X Drilled rotors crack so i guess im staying away from those I don't need that happening lol..
Please post links on brake pads, rotors, and calipers.
cslix is offline
Old 04-25-2013, 06:28 PM
2005Redfire6
2005Redfire6's Avatar
I wouldn't go with that "power stop kit"...
Get this for the front:
http://www.americanmuscle.com/ford-r...de-0511v6.html
With Hawks HPS pads all the way around, plenty sufficient and you will be happy.
http://www.americanmuscle.com/mustan...pads-0510.html
2005Redfire6 is offline
Old 04-25-2013, 07:04 PM
cslix
cslix's Avatar
Hey thanks for the advice but two things. One i forgot to mention im only looking to spend around $200-$350 for the front and back rotors and pads and even calipers. Second is a question.. Do you have to have a bigger rim for the ford racing gt upgraded caliper brackets and rotors? I have stock rims and tires.
cslix is offline
Old 04-25-2013, 07:31 PM
2005Redfire6
Are they the 16" wheels? Which wheels are they? Also you don't need to change your calipers, if you did you would be looking at $600+ and thats just for the front.
Old 04-25-2013, 07:37 PM
cslix
cslix's Avatar
Not positive but i think there 16" with all season tires..
I will try to measure tomorrow. But if they are 17" then im guessing your going to tell me to buy the kit lol.
cslix is offline
Old 04-26-2013, 05:56 AM
2005Redfire6
You can look at the writing on the tire and it will tell you. If you want you can just get the same size replacement rotors if you need them and just get pads, but you really don't need new calipers...
Old 04-26-2013, 04:12 PM
cslix
cslix's Avatar
even with 120k miles.. and ok
cslix is offline
Old 04-26-2013, 04:35 PM
aaquib1992
aaquib1992's Avatar
I think the 05 V6s only came with the 16" wheels, so you likely won't have the clearance to do a rotor upgrade. However, some good pads (as redfire said) will do you A LOT more good than any rotor upgrade.
If you want stronger brake feel, and less dead pedal, you could look into stainless steel brake lines, I don't know if there are any made for the V6 without ABS, however I think there are some aftermarket options for SS brake lines for V6s that did come equipped with ABS.
I have hawk HPS pads and they are pretty awesome compared to OEM, I would suggest you take a look at them and the ceramic pads that hawk makes and find which one suits your needs better.
aaquib1992 is offline
Old 04-28-2013, 01:54 PM
2005Redfire6
Love my hawk pads as well, just dusty as hell.
Brett Ludlow
09-23-2015 06:59 AM
2015Ecoboost
09-17-2015 01:48 PM
DoctorScary
09-09-2015 07:53 AM
tj@steeda
Steeda Autosports
09-08-2015 11:50 AM
Quick Reply: Opinions On Decently Priced Brakes
