Still breaking up after 3,000rpm...what else to check?
Old 04-28-2013, 05:22 PM
StalkerGT
StalkerGT's Avatar
Default Still breaking up after 3,000rpm...what else to check?
I have replaced my tfi module and ignition coil...when I hit 3,000-3,500rpm's it breaks up and the tach kinda bounces around. If I full throttle it it seems ok but if I hold it steady around 3,500 that's when starts to bounce around and break up....if the car is just sitting and I rev it up to that it doesn't do it. Seems to be only when driving. What else should I check? I'm stumped
StalkerGT is offline
Old 04-28-2013, 08:36 PM
mattdel
mattdel's Avatar
EGR related vacuum lines would be a good start.
mattdel is offline
Old 04-29-2013, 06:10 AM
StalkerGT
StalkerGT's Avatar
Ok I will check out the vacum lines today
Old 04-29-2013, 08:13 AM
uedlose
uedlose's Avatar
coil, the pick inside the distributor and the shaft in the distributor check it for wear from side to side I have seen a few wear out. Then you might want to start looking at valve springs
uedlose is offline
Old 04-29-2013, 09:09 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
to me it sounds like a fuel pump...have you checked the pressure?
rmodel65 is offline
Old 04-29-2013, 09:55 AM
Js88lx
Js88lx's Avatar
Good voltage?
Js88lx is offline
Old 04-29-2013, 11:07 AM
uedlose
uedlose's Avatar
The tack jumping around kind of say electrical to me But I could be wrong that's for sure
uedlose is offline
Old 04-29-2013, 01:24 PM
StalkerGT
StalkerGT's Avatar
All vacum lines checked out ok...my fuel pressure is about 36-37psi with vacum on at idle. The regulator is new...fuel pump is Walbro 255 that was put in last summer. Now it's just doing it around 4,000 and when I let off the gas as the rpm's drop the tach still jumps around without hitting the gas pedal...but when the rpm's get under 3k it's fine and stops jumping. If the car is sitting and I rev it up to around 3,500 and hold it there it breaks up pretty bad...it doesn't really do it when the car is cold...just when it gets around 180 or higher. Sometimes cranks for a few seconds before it starts too. That's also when it is warmed up
Old 04-29-2013, 02:42 PM
StalkerGT
StalkerGT's Avatar
Fuel pressure is at 42 with vacum off...also realized today that when I slowly press the throttle the fuel pressure goes down a few psi. But if I hit it fast it goes up like it should. I stopped by a garage today and they suggested maybe the distributor but almost seems fuel related now? When the car is cold fuel pressure is around 37 at idle but when fully warmed up its at 34 at idle
Old 04-29-2013, 04:26 PM
mattdel
mattdel's Avatar
The tach is exclusively controlled by the negative wire of the coil, so if it's acting weird in any way it's either the wiring, the coil, or the tach. The breakup can be explained by anything else mentioned here, but it would be rare that they aren't connected.
mattdel is offline
Quick Reply: Still breaking up after 3,000rpm...what else to check?
