Front Shocks not aligning
Old 04-29-2013, 03:42 PM
JoeWilke
JoeWilke's Avatar
Angry Front Shocks not aligning
I'm in the middle of replacing my entire front suspension on 64 Coupe. When installing the shock, I find that it doesn't align properly from upper control arm to upper shock mount. Do I have to use spacers in order to align the shock square???
Thanks
JoeWilke is offline
Old 04-29-2013, 05:08 PM
1slow67
ROTM Moderator
1slow67's Avatar
How does it not align?
1slow67 is offline
Old 04-29-2013, 05:36 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i assume his spring perch needs to be slightly rotated...stick a pry bar in there and get it right..then bolt the bottom of the stock in remove the wire holding the shock in and let it expand then bolt in the top
rmodel65 is offline
Old 04-29-2013, 07:11 PM
JoeWilke
JoeWilke's Avatar
Thanks. I will try adjusting the perch again, but seems that it is as far as it will go. Photo attached. Gap on one side of shock is the width of my finger, other side is flush with perch.
Thanks for your help guys!
JoeWilke is offline
Old 04-29-2013, 08:37 PM
1slow67
ROTM Moderator
1slow67's Avatar
Tried putting a jack under the LCA and jacking it up a little?
1slow67 is offline
Old 05-01-2013, 09:52 AM
1970's Avatar
i had to put a jack under my uca
1970 is offline
Old 05-12-2013, 10:39 AM
Diputado
Diputado's Avatar
Has this car ever been in any kind of front-end collision? Maybe some structural misalignment if so?
Diputado is offline
Old 05-14-2013, 08:37 PM
67mustang302
67mustang302's Avatar
I usually snug the bottom bolts on the perch first, then muscle the upper into aligning with the mounting holes.
That's common, once the shock is removed the way the spring sits on the perch combined with the position of the arm causes the perch to tilt to one side. Especially on a new install where things haven't settled into a normal ride height position yet.
67mustang302 is offline
winner99
10-01-2015 01:06 PM
winner99
10-01-2015 10:52 AM
mdg
10-01-2015 07:04 AM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Front Shocks not aligning
