Oil blowing out RADIATOR. No oil in block, no coolant in oil
Old 05-02-2013, 06:19 PM
Doublevision
Doublevision's Avatar
Default Oil blowing out RADIATOR. No oil in block, no coolant in oil
1998 4.6 GT 5 speed
Today I noticed oil under the car but it was under the nose, opened the hood and oil was billowing out the radiator mixed in the coolant. Pulled the oil dipstick and no oil left in the engine, BUT NO COOLANT in the oil.
What do I need to check? Is there anywhere I can look without pulling the heads since it is not a blown head gasket in the traditional sense?
I've heard possible intake gasket??? If so can I get some pointers on where and what to look for?
Doublevision is offline
Old 05-02-2013, 07:00 PM
Doublevision
Radiator is overflowing and dipstick is dry so oil fully emptied into coolant. 5+ quarts
Oil in heads is CLEAN. No coolant.
Old 05-02-2013, 07:40 PM
edwin108
edwin108's Avatar
I'm thinking you have either a blown head gasket or a damanged oil filter adapter gasket/o-rings. I found a thread with a similar issue: https://mustangforums.com/forum/4-6l...lp-please.html
edwin108 is offline
Old 05-02-2013, 08:15 PM
Doublevision
Thank you for the link, but did you read the last post? I more confused now than before. Lol
Old 05-02-2013, 08:32 PM
edwin108
edwin108's Avatar
I would look into the oil filter adapter gasket/orings first as it seems way easier (and cheaper) to replace than head gaskets.
edwin108 is offline
Old 05-02-2013, 08:38 PM
Doublevision
Agree. Thanks
Old 05-02-2013, 09:55 PM
Doublevision
Well I can't see any evidence of blow through, but I'm going to shave it and stick a new gasket in there to see what it does. Could the adapter be leaking itself inside the bottom area?
Old 05-03-2013, 07:46 AM
edwin108
edwin108's Avatar
Maybe you could try forcing some air/water into the oil passages of the adapter to see if it comes out of the coolant side?
edwin108 is offline
Old 05-03-2013, 11:06 PM
Fastblackstang
Fastblackstang's Avatar
I am gonna say to check the head gasket mine went and did the same thing, it depends where the head gasket is torn. Also have to remember that compression is stronger then water pump, which would cause oil to be forced into the coolant.
Fastblackstang is offline
Old 05-04-2013, 04:29 AM
Doublevision
Changed the oil plate gasket so we will see how it goes. It'll take a few days to get all that damn oil out of the radiator. I've flushed it 8 times already tonight and it is still shooting oil spurts out the drain so it's going to take a bit. The only way I can really tell right now is to watch the oil level. It was bone dry when this issue surfaced the other day as it was all in the radiator.
There is a better design to the newer blue gaskets. The plastic encases the rubber seals on the blue one versus the orange one the seals hang over the edge of the gasket. This must have been an issue that caused a redesign so hopefully that was leaking and the new one fixes everything up. *crossing fingers*
Quick Reply: Oil blowing out RADIATOR. No oil in block, no coolant in oil
