1988 Ford Mustang GT Hatchback - "Andariel the Demon DD"
Old 10-04-2013, 10:52 AM
  #31
mtflyboy25
mtflyboy25's Avatar
Well.... Spoiler... I bought some boost for the stang... I wanted it to be faster!
I have a metric crap ton of work to do on the car right now though and sadly I dont think I will have it running in time to go to the October Mustang Meet at my local drag strip
Things to do:
Remove SMOG
Remove Pass Header
Weld flange back on to pass header at the H pipe connection
re install pass header
make sure all smog deletion is A ok and car still runs
unpack and sort boosting stuff Not telling yet..
install boosting stuff...
find a drivers seat...-sold my front seats to buy racing seats...I got the brackets and then came upon a killer deal for my boost and couldnt resist...Also bought a welder so i am limited on funds for a seat
go get car tuned!!!!!!!!!!!!! another $500 i dont have yet
mtflyboy25 is offline
Old 10-10-2013, 05:46 PM
  #32
mtflyboy25
mtflyboy25's Avatar
Well I got all of the smog stuff off including the egr pips that go to each side of the head on the back. I also pulled off my passenger header. A nightmare in itself, then I welded it where it had broken in the bottom connection to the h pipe. I need a lot more practice welding...
I think it is at least good enough to hold though so I let it cool off and then put it back on. That Sucked. My fingers feel blistered from trying to turn the header bolts so hard. But in the end I succeeded and I think I am solid on that at least now. I need to bend or cap or something the h pipe which had a connection for the smog system. Also I need those plugs for the heads because major leak back there when you crank it up. Far too loud to tell if my header is leaking or not. Oh well those come Thursday. In the meantime.... Pics of supercharger! An other stuff
Some smog stuff
Before...
Clean garage!
Yay boxes. I love ups. Man he wrapped this stuff well.
Screw big air maf
Power pipe
Individually wrapped 60# injectors
Gave me a goal showing me his best et
Boooom
Bracket with empty smog housing for me
8 rib? Woot!
Even came with original instruction booklet.
Ramblings brought to you by tapatalk on the iPhone.
Old 10-21-2013, 12:14 PM
  #33
mtflyboy25
mtflyboy25's Avatar
Seats are in.... too wide and crush the center console lol....
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
Old 10-21-2013, 12:15 PM
  #34
mtflyboy25
mtflyboy25's Avatar
Old 10-30-2013, 08:58 AM
  #35
mtflyboy25
mtflyboy25's Avatar
Progress!
old 24#s
getting closwer!
sexy
wow they are silver!
problems...
had to put the smog pulley back on...
now it works...
tight tho..
looks oh so nice...
Old 10-30-2013, 03:13 PM
  #36
mtflyboy25
mtflyboy25's Avatar
Found some chrome under that plasti dip!!!
New Corbeau FX1 Pro's!!
Old 10-31-2013, 01:26 PM
  #37
mtflyboy25
mtflyboy25's Avatar
Old 11-06-2013, 10:06 AM
  #38
mtflyboy25
mtflyboy25's Avatar
Got tuned! 308 RWHP / 365 ft lbs on a Mustang Dyno
Went out and played too!
Updated mods list...
Engine
Stock E7TE Cylinder Heads
E303 Camshaft
Professional Products Powerforce Plus Harmonic Damper #90007
Professional Products Powerforce Spacer for Ford #81007
Edelbrock Victor High Flow Water Pump
60 lb. Injectors
GT40 Tubular Upper Intake
GT40 Lower Intake
SCT BA2400 Calibrated for 60 lb injectors
Anderson Power Pipe for Vortech
Vortech V1 HO Supercharger Kit
8 rib/6 rib HO Crank Pulley pulley
3.33 8 Rib Supercharger Pulley
MSD 6A Ignition Coil
Black Magic Extreme 3300 CFM Fan
Fluidyne Aluminum 3 core radiator
BBK Shorty Headers
BBK H Pipe
Flow Master Mufflers
Ford Racing 8mm Spark Plug Wires
Professional Products Adjustable Fuel Pressure Regulator
BBK Underdrive Water Pump Pulley
65mm Throttle Body
65mm EGR Spacer
Lentech Street Terminator AOD Transmission
9.5 inch converter = 2600 stall
Hayden Transmission Cooler
Chrome Ford Racing Transmission Pan
Poly Transmission Mount
130 Amp Alternator Swap
Optima Red Top Battery
190 lph Fuel Pump
T-Rex Inline Add a Pump
Suspension
Kenny Brown Double Cross Subframe Connectors Welded
Global West Strut Mounts
Global West Rear Control Arms
Poly Sway Bar Bushings
5 lug conversion
16 inch Chrome Cobra Replica Wheels
96 Mustang 2 piston caliper polished Front Brakes
04 Cobra Differential
3.27 Gears
31 Spline Axles
Aluminum 1 Piece Ford Racing Drive Shaft
Wilwood Adjustable Brake Proportioning Valve
1993 Cobra Master Cylinder
Stock Brake Booster
BBK Lowering Springs
KYB Rear Shocks
Interior
Corbeau FX1 Pro Racing Seats
Corbeau Dual Locking Race Seat Brackets
New Black Carpet Front & Rear
New Black Seat Belts Front & Rear
New Black Premium Door Panels
New Black Dash Pad
New Black Door Arm Rest Pads
New Black Center Console Arm Rest Lid and Rebuild
New Black Door Skid Plates
New Black Headliner
New Black Sun Visors
Painted All interior Pieces Black if not bought new
Exterior
Black Housing One Piece Headlights
Smoked Black LED Tail Lights
Smoked Fog Lights
Antenna Delete
Old 11-16-2013, 10:36 PM
  #39
mtflyboy25
mtflyboy25's Avatar
Went and raced it
11/16/2013 Drag Racing
5140 DA
Best ET of 13.56
Best Trap of 110.52
Race Weight of 3448 with driver
Old 08-18-2014, 04:31 AM
  #40
Jace 5.0
Jace 5.0's Avatar
really sweet ride there! i wish mine would smoke the tires up like that. also im really digging those headlights. might have to buy some of those for myself.
Jace 5.0 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
08-10-2015 01:44 PM
Quick Reply: 1988 Ford Mustang GT Hatchback - "Andariel the Demon DD"
