need help. exhaust leak out intake?
Old 05-03-2013, 10:29 AM
cheapstreetduster
cheapstreetduster's Avatar
Default need help. exhaust leak out intake?
im experienceing an exhaust leak but cant seem to find it..
ive narrowed it down to the pass ..but visually i cant find any leak in the main pipe or headers or header gasket..
is there a part somewhere on the intake that can fail and create an exhaust leak..
im looking at the exhaust gas crossover pipe..it looks fine.
and the egr is located at the front of the motor...
the noise is comming from the back...any advice on an item or part or gasket area that could give me the exhaust leak.?
fwiw..after about 1-2 minutes it goes away. after a cold start up...and im having a hard time finding it in that short period of time.
thanks
cheapstreetduster is offline
Old 05-03-2013, 10:39 AM
cheapstreetduster
i should add..it had the crack in the lower weld....the common area where the dehumidifier water drips on it..
i had this dis assembled and rewelded..and a drain line installe on the condensation drain so it no longer runs on the pass side exhaust...
i dont see any visual leaks at this location...it seems to be comming more up like i said at the pass side intake...
and not the header flange...
Old 05-03-2013, 11:50 AM
gt281
gt281's Avatar
Get some seafoam. Follow the directions for cleaning the intake (putting it in the brake booster vacuum hose) and the smoke should help you find your exhaust leak.
gt281 is offline
Old 05-03-2013, 12:31 PM
AMWill
Former Sponsor
AMWill's Avatar
Agreed^^^ Get the engine smoke tested. It makes things really easy when you're not able to find a leak. It should only take a few minutes, too!
Shane
AMWill is offline
Old 06-11-2013, 06:49 AM
petrock
petrock's Avatar
If its an exhaust leak, get a squirt bottle and fill it with soapy water. Squirt all over the exhaust manifold & manifold to exhaust pipe joint and start the car. If there is an exhaust leak you’ll see bubbles pretty quickly. Good luck...
petrock is offline
mirandaandjimmy
11-16-2015 08:51 AM
mryeah256
08-28-2015 02:01 PM
91StangOwner
08-20-2015 11:34 PM
11GTBlu
5.0L V8 Technical Discussions
08-10-2015 05:56 PM
Itstbrown
08-09-2015 03:49 AM
Quick Reply: need help. exhaust leak out intake?
