3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
OBD2 code "U0401" ?
Old 05-03-2013, 04:01 PM
Moronix
Moronix's Avatar
Thumbs down OBD2 code "U0401" ?
After installing my Airaid CAI I got this code "U0401" from Hypertec tuner(Not sure the CAI has anything to do with it). I connected my OBD2 reader and it shows a "yellow" light and some flashing indicators..."C, EV, O, CH, E". My OBD2 reader evidently does not show "U" codes but the manual indicates the computer is monitoring these values and hasn't finished yet. So the check engine light is not on. Telling the OBD2 reader to "erase" does nothing since on the next "read" it shows the same indication. Question is will the computer eventually stop monitoring these values and go back to normal or does it really require work?
Moronix is offline
Old 05-03-2013, 08:02 PM
JimC's Avatar
I found this on a google search for that code:
http://ww2.justanswer.com/uploads/sd...ight_is_on.pdf
Not for a Mustang, but that code is for the transmission control module it says.
JimC is offline
Old 05-04-2013, 07:02 AM
Moronix
Moronix's Avatar
JimC Thanks for the infor but it's for cars with CVT (not Mustang). The code actually indicates something like "invalid data sent to ECM/PCM". I guess something unusual happened and sent the wrong data which caused the computer to start extra monitoring of the oxygen, exhaust gas recirculating system and other stuff. Evidently it's not serious enough to cause the "check engine"lite to come on. I just wonder if it will settle down and go back to normal by itself or do I need to take it to the shop. Since I only have 1300 miles on it, it's in warranty.
Moronix is offline
Old 05-04-2013, 11:28 AM
Joenpb
Joenpb's Avatar
It might just need a battery disconnect reset and a throttle relearn because of increased airflow.
http://www.allfordmustangs.com/forum...ml#post3483505
Thousands of Airaid CAIs have been installed without issue, so if the issue remains you may have a defective piece of hardware. Good luck.
Joenpb is offline
Old 05-04-2013, 11:54 AM
157dB
Cut & Paste Expert
157dB's Avatar
http://iihs.net/fsm/?dir=10&viewfile...scriptions.pdf
This will tell you U codes...
157dB is offline
Old 05-04-2013, 05:30 PM
Moronix
Moronix's Avatar
Been doing a little reading and it appears my problem may have been created by just disconnecting my battery when installing my CAI. Little more research and a couple more days and I should know for sure.
Moronix is offline
Old 05-05-2013, 11:09 AM
Moronix
Moronix's Avatar
It appears that just clearing a DTC code will "reset" the status of all monitors to a not run "flashing" condition. There are a max of 11 monitors available and all are not used as of yet. A "drive cycle" has to be accomplished or maybe 2 or 3 drive cycles to set all the monitors to a "Done" status (not flashing). Finding the right "Drive cycle" to accomplish is not easy. I found one online and tried it and 2 of my monitors stopped flashing. I did another drive cycle this morning and 1 more monitor stopped flashing. I now have 2 monitors left flashing. They are the "O" and "OH" monitors. I guess tomorrow I will try another "Drive cycle" to see if they clear up.
It also seems that simply disconnecting your battery (per the Airaid CAI instructions) will also reset the monitors. I did both since I disconnected the battery before installing my Airaid CAI. Then when I tried to instll the tuner I got the "U0401" code and tried to reset the code. Don't know what caused the U0401 code and telling the tuner or the OBD2 reader to erase it does not erase it. More later.
Moronix is offline
Old 05-23-2013, 07:52 PM
lynxwolf
lynxwolf's Avatar
There is a recall on the 13 Auto V6 When i bought mine it was on the carfax
lynxwolf is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: OBD2 code "U0401" ?
