Does this seem slow to you?
Old 05-06-2013, 02:02 PM
mtflyboy25
mtflyboy25's Avatar
Originally Posted by StalkerGT
I think it should be in the high 13's at the least. When I first got my car it went 14.5@96 with stock heads and cam, 2.73's, crappy street tires and didn't have a good tune up done
I bet the DA wasnt 4500 and you didnt have a 2600 stall which didnt let you hit power til the 330 ft?
mtflyboy25 is offline
Old 05-06-2013, 05:23 PM
bluebeastsrt
bluebeastsrt's Avatar
It should run those times at see level. The DA & sixty is killing the times.
bluebeastsrt is offline
Old 05-06-2013, 05:56 PM
StalkerGT
StalkerGT's Avatar
Ohhh gotcha....didn't know it made that much of a difference. Well obviously the 60 ft time does
StalkerGT is offline
Old 05-06-2013, 06:47 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
gearing sucks, heads suck, stall sucks, and your altitude there is a killer, best thing you can do for that combo , rather than start all over, is add a supercharger or turbo, on3 kit = best bang for the buck
mjr46 is offline
Old 05-06-2013, 07:17 PM
bluebeastsrt
Good advice mjr. OP. forced induction is a much better set-up for cars at high DA over a naturally aspirated car.
Old 05-07-2013, 12:46 AM
tinman
tinman's Avatar
One way to sort of beat high density altitude is to use more gear than you would ordinarily use.
Like 4.30 when you would use 4.10 at sea level.
Thats why some cars in stock eliminator in NHRA use such wild gears.
As for as the air goes I know it will only get worse until about the first of October.
I've seen over 7300'A.D. here at Tucson in July........
tinman is offline
Old 05-07-2013, 11:22 AM
mtflyboy25
mtflyboy25's Avatar
Yeah I wish I could run at seas level. Last place I ran was Bandimere in Denver, CO. So I only know about high altitude 5000+ DA drag racing haha.
It makes a huge difference. At Bandimere you lost basically 2 seconds on a stock NA car.
I agree with you man... on3 ? I have never heard of them? $1600 for a full kit is a DAMN good price, but makes me think it lacks quality pieces. Do you have any experience with it?
Yes 3-5 lbs of boost generally overcomes the losses from high altitude.
I have seen crazy gears but this is a Street / Strip car, so I will most likely stay with my 3.27s for that 2.1 k 70 mph cruising speed. Its great for the mpgs...
I am used to 7000+ DA... I normally raced at 8500 at Bandimere in the summers in my old 2011 GT. I just want to run faster than it... I ran a 13.06 @108.7 mph there...
The speed mods will come later though. Right now I have to make her look good. Full interior black is on its way...
Old 05-07-2013, 11:40 AM
mjr46
mjr46's Avatar
yes i have experience with it, installed one for a friend, he to runs ported e7 heads, the turbo will make up for the shortfalls in the combo, with 12-14 lbs of boost on a simialar build be made 479 to the tires and ran 11.2 @123
mjr46 is offline
Old 05-07-2013, 04:46 PM
  #19
mtflyboy25
mtflyboy25's Avatar
That isnt half bad...
Old 05-07-2013, 06:19 PM
  #20
darkmach1
darkmach1's Avatar
Before you go throwing more power at this this setup, which will only disappoint you even more, throw a set of DRs or slicks and put it on the dyno to see what it puts down as it may need a tune. These 2 things might be all you need.
darkmach1 is offline
Quick Reply: Does this seem slow to you?
