Engine Question Regarding Cylinders
Old 05-06-2013, 10:00 PM
Herz
Herz's Avatar
Default Engine Question Regarding Cylinders
I have the 4.6 DOHC in my 96 and after replacing the plugs and coils find that cylinders 1 and 3 are both bad. My engine only has 80k on it and I really don't want to replace it with other engines out there with more miles. I know it will probably be the best to pull the engine completely out and work on a stand. I am curious to know what kind of job I am looking at to replace my cylinders? Is this going to be worth my time in the long run?
Herz is offline
Old 05-06-2013, 11:01 PM
ZeroTX
ZeroTX's Avatar
Replace the cylinders? What exactly do you mean? Re-sleeve the block? That would be for a machine shop to do.
ZeroTX is offline
Old 05-06-2013, 11:27 PM
AJB540
AJB540's Avatar
I honestly think I would just buy a new block at that point. You can find them cheap enough at junk yards.
AJB540 is offline
Old 05-07-2013, 08:00 AM
Herz
Herz's Avatar
Sry I think I was tired last night. I meant changing the pistons.
Herz is offline
Old 05-07-2013, 09:20 AM
Seabee1993
Seabee1993's Avatar
Have you done a compression test to be sure it's your pistons/rings that are bad?
Seabee1993 is offline
Old 05-07-2013, 09:38 AM
Herz
Herz's Avatar
Yes I have that's how I found out 1 and 3 were working properly.
Herz is offline
Old 05-07-2013, 10:29 AM
BraMas
BraMas's Avatar
what are the comp. results for all 8 cylinders? could also be a valve problem
BraMas is offline
Old 05-07-2013, 10:54 AM
Herz
Herz's Avatar
1 had 0 and 3 had 75, the rest were normal.
Herz is offline
Old 05-07-2013, 10:15 PM
BraMas
BraMas's Avatar
Well that sounds like rebuild time. Your options are buy a short block from any # of places on the net that have 4.6 shortblocks
Build it your self will probably by close to 2K when you figure in new Pistons and rings,bearings,gaskets and all new bolts because OEM bolts are TTY (one time use). I'm sure you can do it cheaper than $2K but you really have to shop around for good prices
BraMas is offline
Old 05-08-2013, 09:33 PM
ZeroTX
ZeroTX's Avatar
Budget, goals? If you just want to get back to stock performance, you should be able to find a complete motor for your car for $800-900 in excellent condition. If you can't find a '96-98 motor, then a 2001-2011 2v 4.6L Romeo (01-04 Mustang or 01-11 Crown Vic/Marquis/TownCar) can be found with low mileage and nearly as cheap (cheaper if you look for a Vic motor).
ZeroTX is offline
bryan616fl
01-25-2019 09:07 PM
classic69FB
08-12-2015 11:58 PM
$A_Money$81
08-11-2015 01:30 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Engine Question Regarding Cylinders
