what is this hose for?
Old 05-08-2013, 05:34 AM
GTnotchback
GTnotchback's Avatar
Default what is this hose for?
This is an image off the net, not my car but i need to know what is this vacume line for? (the one on the right that curves down under the main harness and into the firewall. thanks
GTnotchback is offline
Old 05-08-2013, 06:34 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I think that's the vacume line that runs your heating/cooling switches. The ductwork under the dash has vacume operated doors/panels for defrost, heat, vent etc.
Old 05-08-2013, 07:27 AM
arnie93lx
arnie93lx's Avatar
Yes, that is the vacuum source for your HVAC which connects under the dash assembly.
arnie93lx is offline
Old 05-08-2013, 08:08 AM
GTnotchback
ahhh. I do not have this 3 way anymore on my car. No wonder only defrost mode works lol! can i hook just that one line into my main vac tree? I dont think it would get too much vac then would it?
Old 05-08-2013, 08:15 AM
I may be wrong but the round piece ther in the pic is a damper of sorts to control the speed at which the vacuum is applied so the doors don't smack open and closed..
Old 05-08-2013, 09:57 AM
GTnotchback
i found a diagram that says that is a check valve. Im not sure of its purpose. I dont see air flowing the wrong way?
Old 05-08-2013, 10:07 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
its for when the vaccuum dumps when you open the throttle it doesnt dump all the vacuum in the lines otherwise the vents would be constantly switching from the dash to defrost everytime you left a traffic light
rmodel65 is offline
Old 05-08-2013, 12:06 PM
GTnotchback
ok that makes sense now. thanks guys!
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
lmurf60
09-24-2015 10:07 PM
Demodulates
09-18-2015 11:14 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: what is this hose for?
