Camshaft movement
Old 05-09-2013, 06:41 PM
gnx547
gnx547's Avatar
Default Camshaft movement
I installed the cam and thrust plate. The cam moves in and out a little bit. Should there be no movement at all?
gnx547 is offline
Old 05-09-2013, 08:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there should be some movement, you'll have to measure it to see if end play is within spec
mjr46 is offline
Old 05-10-2013, 10:20 PM
gnx547
gnx547's Avatar
A few months ago I bought a Cloyes timing chain (part number 9145) and today I tried putting it on and it does not fit. The teeth won't go into the chain nice and even. What timing chain should I buy that will fit?
gnx547 is offline
Old 05-10-2013, 11:37 PM
tinman
tinman's Avatar
I think if the camshaft movement exceeds .009 they want you to replace the thrust plate.
tinman is offline
Old 05-11-2013, 02:27 PM
Duncan_GT
Duncan_GT's Avatar
Yeah .004-.008 end play, I believe.
Duncan_GT is offline
Old 05-12-2013, 12:03 PM
mjr46
mjr46's Avatar
i run .005 on my torrington set up iirc
mjr46 is offline
djbigskrilla
09-20-2022 01:04 AM
NYstang
09-30-2015 09:56 PM
uberstang1
09-20-2015 06:42 PM
MonsterBilly
09-20-2015 06:56 AM
Redneck1465
08-08-2015 10:39 PM
Quick Reply: Camshaft movement
