Valve Covers
Old 05-09-2013, 07:31 PM
ron.gcp
ron.gcp's Avatar
Default Valve Covers
I've been wanting to put some after market valve covers on my 302 but noticed some sites say for carburetored engines. Does this mean they will not fit fuel injected?
ron.gcp is offline
Old 05-09-2013, 09:08 PM
reldla1996
reldla1996's Avatar
The upper intake on a fuel injected engine limits how tall the valve covers can be. Sometimes you have to add an intake spacer to clear a valve cover. Look at what others have done, and you will know what will clear. Otherwise they are identical.
reldla1996 is offline
Old 05-09-2013, 09:30 PM
darkmach1
darkmach1's Avatar
Takes some work but can get it to work if you really want the upgrade.
darkmach1 is offline
Old 05-10-2013, 04:22 AM
ron.gcp
ron.gcp's Avatar
Thanks for your responses.
ron.gcp is offline
Old 05-10-2013, 08:37 AM
darkmach1
darkmach1's Avatar
Clearance areas to consider are... TB bracket to new valve cover clearance, upper intake to new valve cover clearance, oil fill/ crankcase vacuum hose placement and hood to upper intake clearance because of the use of a spacer. To make mine fit I had to use a 1" and a 3/8" spacer to make the systemax upper not hit the cover, I plugged the new valve cover hole on the drivers side, I deleted the EGR and a it's spacer for TB bracket clearance and used a valve cover breather on the passenger side valve cover which is also my oil fill port.
Old 05-10-2013, 10:52 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
personally id just get a set of the stock covers that are polished or just polish what you got..
rmodel65 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
winner99
10-01-2015 01:06 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: Valve Covers
