2004 Mach 1 5 Speed Transmission.. Tranny Fluid?
Old 05-09-2013, 09:53 PM
Hob
Hob's Avatar
Default 2004 Mach 1 5 Speed Transmission.. Tranny Fluid?
I've read all over that our Mustangs use Dexron III but the only Dexron I see at Autozone is Dexron VI?
Is this what I should be using on my 5 speed transmission flush?
Hob is offline
Old 05-09-2013, 10:22 PM
Sonic Mustang
Sonic Mustang's Avatar
Back in 2003/2004, Ford specified MERCON III ATF in the Tremec 3650 5 speed transmission in your Mach 1. Now, Ford specifies MERCON V for all applications requiring MERCON III.
Tremec, the manufacturer of the 3650 specifies Mobil 1 ATF OR DEXRON III. See page 8 of the Tremec 3650 Service Manual:
http://www.ttcautomotive.com/English...ice_Manual.pdf
Note that Tremec specifies 3.8 liters of ATF.
Ford has since revised its fluid capacity for the 3650 to 3.0 liters:
http://www.stangnet.com/images/stori...s/04-15-06.pdf
A lot of guys run synthetic manual transmission oil, but I avoid it. According to a Tremec engineer I spoke with, some of the materials used in the 3650 specifically require an ATF.
Sonic Mustang is offline
Old 05-09-2013, 11:11 PM
Hob
Hob's Avatar
Exactly what I needed to know. Thank you sir for the updated information!
Additionally I have another question.... I've read that the Mercon V is used in the power steering system as well is this correct on these generation Mustang?
Hob is offline
Old 05-10-2013, 12:34 AM
Sonic Mustang
Mercon V is the replacement for Mercon III for all applications calling for Mercon III.
Mercon V has been in my power steering system for years.
Old 05-10-2013, 03:01 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
I have had best results with my '03 GT running Mobil 1 ATF (3.0 L), much smoother shifts than with GM Syncromesh or RP Synchromax...
cliffyk is offline
Old 05-10-2013, 05:51 AM
audioAl
audioAl's Avatar
Great thread, any other options for 3.7 auto's?
audioAl is offline
Old 05-10-2013, 08:57 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
I bet someone in the 2005-2013 section might have some...
cliffyk is offline
prophotog
09-15-2015 08:38 AM
jaiidutch
09-14-2015 10:29 AM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
iamgobono
09-03-2015 12:37 PM
Quick Reply: 2004 Mach 1 5 Speed Transmission.. Tranny Fluid?
