Best swaybars for neutral handling?
Old 05-12-2013, 11:47 AM
M3hunter
M3hunter's Avatar
Question Best swaybars for neutral handling?
Hi Guys,
Which are the best swaybars for neutral handling in a '10-'14 Mustang GT (no understeer or body roll)?.
Please specify if you are squared or staggered)
M3hunter is offline
Old 05-12-2013, 05:37 PM
jayman33
jayman33's Avatar
Are you tracking your car? If not the best way to improve handling in these cars is better shocks and struts. The sways on these cars aren't all that bad.
jayman33 is offline
Old 05-13-2013, 10:56 AM
908ssp
908ssp's Avatar
Sway bars really can't or shouldn't be considered alone. They work side by side with spring rates and tires. Handling is the sum of all parts. You can consider upgrading in steps according to your feel for what you want but that may or may not be the "best" or even an improvement.
I am sensitive to feel in the steering wheel the soft rubber used in the front control arm bushings lacked feel for me. I also changed to wider and shorter side wall tires. Stiffer springs solved the sway issue and much better shocks solved the damping issues. A slight increase in rear sway bar size decreased under steer so that now I am happy.
908ssp is offline
Old 05-13-2013, 08:09 PM
M3hunter
M3hunter's Avatar
Right now I have KONI STRT + STEEDA Sport Springs, wider rear Michelin Super Sport tires 275/40 R19 mounted on 19X9, front ones are the stock 255/40R19 pirellis. Yes I'm planing to track the car, but looking for improvements like sways and watts link
M3hunter is offline
Old 05-14-2013, 03:55 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
These work well, and the front bar is adjustable so you can dial in the handling balance you want.
http://www.uprproducts.com/eibach-mu...ar-kit-11.html
UPRSharad is offline
GimpyHSHS
19
12-19-2023 01:12 PM
firehorse02
11-16-2015 11:28 AM
guitarman376
09-30-2015 05:54 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Best swaybars for neutral handling?
