Clutch Adjustment - Firewall dial???
Old 05-14-2013, 06:22 AM
Gary Ugarek
Gary Ugarek's Avatar
Default Clutch Adjustment - Firewall dial???
OK, so I picked up this 2000 GT Convertible yesterday. The clutch has 5k on it, but they set the release really high, I mean top end of the pedal
So the guy says to turn the adjuster on the firewall to change the grab, only problem is he didn't say which direction.
At lunch I would like to go out and adjust the grab on the clutch
So do I turn this clock wise or counter clockwise?
Gary Ugarek is offline
Old 05-15-2013, 05:38 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Clockwise--you want to loosen the cable to move the engagement point lower. However it should be adjusted so there is 1 to 1-3/8" of free play in the pedal--press on the pedal with your hand, it should move 1 to 1-3/8" before you feel the throwout bearing begin to compress the spring fingers...
cliffyk is offline
Old 05-15-2013, 07:30 PM
Gary Ugarek
Thanks Cliff
Old 05-15-2013, 10:19 PM
uberstang1
Chupacabra
uberstang1's Avatar
Gary if your looking to change the height of the pedal your best bet is to get a triple hook quadrant and try each hook while adjusting the clutch properly untill you get the desired pedal feel. You just don't wanna adjust the firewall adjuster to the point where you like the pedal, it should be adjusted specifically to how cliff mentioned, and looser and the clutch wont fully disengage when the pedals pressed and any tighter the clutch will be partially disengaged when driving. The first could cause trans damage, the later clutch damage.
uberstang1 is offline
Old 05-16-2013, 04:22 AM
Gary Ugarek
Pedal height is fine, it was the grab point that drove me crazy. The clutch wouldn't engage until the pedal was at the top and almost out. Gave the dial about 10 turns and it seems fine now.
The clutch pedal looks newer, I don't know if it is a replacement pedal from stock or some other type of pedal... looks to new to be original.
I can drive a stick, but adjusting them accordingly is a little out of my mechanical expertise area. Hence looking for advice on the adjust side. Maybe I should have you give a drive Uber and see if you can dial it in.
Old 05-16-2013, 06:41 AM
uberstang1
Chupacabra
uberstang1's Avatar
Next time u have it around ill take a pic, if u have it to loose usually itll be hard to get into gears especially at higher rpms, if its to tight usually the clutch will slip wot
Old 05-16-2013, 08:00 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
^+1, and if you adjust it to accomplish 1 to 1-3/8" of pedal free play it will be just right.
The clutch controls (pedal, quadrant, release lever, pivot ball) have an overall mechanical advantage of almost exactly 10:1 between the pedal and the TOB--meaning that 1" of pedal travel causes the TPB to move 0.1". By setting the pedal freeplay to 1 to 1-3/8" you are setting the TOB to spring finger clearance to 0.1 to 0.1375", pretty close to the 0.1 to 0.125" recommended clearance.
cliffyk is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Clutch Adjustment - Firewall dial???
