Ignition cylinder turns fully but car wont start
Old 05-17-2013, 08:16 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Default Ignition cylinder turns fully but car wont start
Hello guys. I am seeking a little help for my 85. This morning I go to start it and the key goes in the ignition cylinder, I turn it to start and the key turns almost 180-degrees but doesn't start the car. No clicking, no trying to turn the engine over, no starter engaging, nada. A little history, 1985, 170k miles, ignition cylinder was replaced about 2 years (less than 20k miles) ago with a Napa cylinder. Before I replace the cylinder I was wondering if it could be something else.
Thanks,
Matthew
Matt's 95 Stang is offline
Old 05-17-2013, 08:57 PM
bluebeastsrt
bluebeastsrt's Avatar
There is a plastic arm inside the column. It's most likely broken. I had to replace my entire column. It was easier than trying to replace the plastic actuator inside. Columns are cheap on e-bay. The other thing you might need a new ingition tumbler.
bluebeastsrt is offline
Old 05-17-2013, 11:25 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i was gonna say the actual ignition switch... its on the column its like 15$ normally they separate and stop making contact
looks like this basically the plastic will come loose from the metal portion
rmodel65 is offline
Old 05-18-2013, 09:40 AM
Matt's 95 Stang
Resident Ginger
Alright. Thanks guys. If any other ideas come to mind please let me know.
Thanks,
Matthew
djbigskrilla
09-20-2022 01:04 AM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: Ignition cylinder turns fully but car wont start
