How good is the pre 93 AOD?
Old 05-18-2013, 08:46 PM
bw71mach1
bw71mach1's Avatar
Default How good is the pre 93 AOD?
I have a 71 351C Mach1 with a C6. The engine was recently rebuilt into a 408 stroker. I would like to swap out the transmission to an AOD. I would like to buy a used pre 93' AOD and install it. Trying to figure out if the standard AOD is strong enough without a rebuild. It's not going to be raced just a little fun at the stop signs.
bw71mach1 is offline
Old 05-18-2013, 10:28 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
answer=no
mjr46 is offline
Old 05-18-2013, 10:37 PM
bluebeastsrt
bluebeastsrt's Avatar
If it was my car I wouldn't use an AOD. What is it you don't like about the C6? If your looking for something strong You'll want to stick with what you have.
bluebeastsrt is offline
Old 05-19-2013, 07:03 PM
bw71mach1
bw71mach1's Avatar
I was hoping the AOD would allow me to change the rear gear to a 3.90 instead of the 3.31 gear. I'm afraid the 3.90 would cause me to run to many rpms. Just wanting to have a little fun off the line. Don't spend to much time on the interstate but don't want to jackup the rpm's too much.
Old 05-19-2013, 07:07 PM
bluebeastsrt
I doubt it's a daily driver. I wouldn't worry about a few extra RPMs.
Old 05-19-2013, 07:32 PM
bw71mach1
bw71mach1's Avatar
Just did a rpm calculator. Looks like 500 extra rpms at 65 mph between the 3.31 and a 3.90. May just stay with what I have.
Old 05-20-2013, 07:34 AM
holyshift
holyshift's Avatar
When built right yes.....stock....no. Building one will cost more than the c6,depends on what ya wanna spend really. Love my aode though.
holyshift is offline
Old 06-14-2013, 09:02 AM
ruskiegunlover
ruskiegunlover's Avatar
I don't get it or see it. I have known a lot of people who had no issue with their AOD's.....My naighbor has an awesome black 88 coupe 5.0 AOD, with over 250 grand on it, only two filter changes. Still runs strong. He also autocrossed this car for several years.
Is it that people just want a manual? My two have been solid.....My cars have just been drivers, not racers, with only the occassional fun at stoplights or stop signs. No problems. Just don't get the dislike of them...
If I were you I would. If you do drive on the highway occassionally, the high rpms make it noisier and screw your gas mileage. If I had a classic I'd throw either a 5 speed or an AOD in it. But I would consider the AOD.....
ruskiegunlover is offline
Old 06-14-2013, 09:36 AM
mjr46
mjr46's Avatar
Originally Posted by ruskiegunlover
.....My cars have just been drivers, not racers, .....
And that my friend is why you don't see it...................try throwing 4:10's and above at them, throwing some power to them and see where the OD band goes, I 've seen IT PLENTY OF TIMES FIRST HAND with the street/strip guys I deal with who like the best of both worlds
mjr46 is offline
Old 06-18-2013, 07:38 AM
holyshift
holyshift's Avatar
Guy that built mine went 8.90s with his....currently in a different car now. It can be done. Just gotta be built right.
Quick Reply: How good is the pre 93 AOD?
