Error Code P219B
Old 05-18-2013, 09:37 PM
gus_vb
gus_vb's Avatar
Default Error Code P219B
My car is 2012 V6 and has installed BBK LT with Catted Shorty X Pipe since March. 3 days ago I was driving to work when suddenly the CEL Light turned on, so I took my car to the dealership today and they told me that the error codes were p219b (Air/Fuel mixture issue bank 2), p0300 and p0316 (ignition misfire). The dealership told me the error codes were thrown due to the aftermarket parts, I am asumming that the fact that I am getting a wrong reading from the O2 sensor is making the engine run lean and therefore the misfire, is there anything I can do? Are my O2 sensors messed up? Or is this just due to the High Flow Cats and I need a Tune to fix this?
Thanks,
Gus
gus_vb is offline
Old 05-19-2013, 11:55 AM
2005Redfire6
2005Redfire6's Avatar
Thanks,
Gus
Are those the only mods you have? I am not sure about the 3.7 or if it matters N/A. But I know my tuner told me when I put long tubes and high flows on my 4.0 that it would lean it out a bit.
2005Redfire6 is offline
Old 05-20-2013, 12:13 AM
gus_vb
gus_vb's Avatar
Yes that is the only mod I have.
gus_vb is offline
Old 05-20-2013, 08:11 AM
2005Redfire6
You may just need a tune, I would call a performance shop around your area if possible specifically a Mustang shop and get their input. Or, go ahead and get a tune if you can swing it and see if that eliminates it.
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
TCStangerv6
10-11-2015 05:57 PM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Error Code P219B
