2005 GT Center Console Power Outlet
Old 05-20-2013, 11:30 AM
CR26
CR26's Avatar
Default 2005 GT Center Console Power Outlet
Hey guys,
I did some searching on the forum to find that quite a few people have had this issue, but I am still unclear about fixing this:
The power outlet in my center console is not sending power to any of my devices. I checked fuses 61 and 64, both were good but I replaced 64 for good measure..
I assume my next step is removing the console to access the harness, but I'm definitely not looking to take my entire interior apart for this. Is there a way to take the console out without removing my stick shift/dashboard?
Thank you
CR26 is offline
Old 05-20-2013, 11:51 AM
Shouldn't have to remove anything from the dash...
" http://iihs.net/fsm/?dir=461&viewfile=Console Floor.pdf "
Old 05-21-2013, 07:10 PM
CR26
CR26's Avatar
Thanks Derf, I'll have to get into that sometime this week
CR26 is offline
Old 05-22-2013, 05:07 PM
CR26
CR26's Avatar
Updates: I opened up the console to find that the outlet was simply unplugged. I bought the car used so I assume this happened either before the dealer took it or while they put my alarm in (?)
Anyway, I also found another plug that leads nowhere. I was able to see this one through the slot for my e-brake but never though anything of it. I'll get some pictures up of it.
http://tinypic.com/r/4zteg0/5
http://tinypic.com/r/2wlwjzq/5
CR26 is offline
Old 05-22-2013, 07:46 PM
JimC's Avatar
Is your car a manual transmission? If so that plug that goes nowhere is probably for the automatic. It is cheaper for Ford to have one common wiring harness and just not use that plug.
JimC is offline
Old 05-22-2013, 11:17 PM
CR26
CR26's Avatar
Yes it is a manual, thank you very much!
CR26 is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
JayGee
09-15-2015 12:41 PM
zanemoseley
09-06-2015 12:58 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: 2005 GT Center Console Power Outlet
