3.8 V6 in a 1995 Ford Mustang
Old 05-21-2013, 07:07 AM
billiemself77
billiemself77's Avatar
Question 3.8 V6 in a 1995 Ford Mustang
My question is I just put a 3.8 V6 in a 95 Ford Mustang and as soon as it cranks up it will die and I cant seem to figure out what the problem could be
billiemself77 is offline
Old 05-21-2013, 07:21 AM
Stevo86
Stevo86's Avatar
You didn't do something right. Check your work.
Stevo86 is offline
Old 05-25-2013, 10:35 PM
go-part
Former Sponsor
go-part's Avatar
Check and make sure all your sensors are plugged in correctly.
Also be sure you have proper fuel pressure at the rails.
go-part is offline
Old 05-25-2013, 11:03 PM
jthorn9
The Godfather
jthorn9's Avatar
Try unplugging the fuel relay switch in the trunk then plugging it back in, this resets the fuel system.
If that doesn't work, then odds are you forgot to hook something up or hooked something up in the wrong order.
jthorn9 is offline
Old 05-26-2013, 08:58 AM
Stevo86
Stevo86's Avatar
That is the inertia switch and no it doesn't "reset" the fuel system. If it is jarred it will create an open circuit which shuts off power to the fuel pump. Pressing the red button resets the switch after it has been tripped but otherwise does nothing.
Stevo86 is offline
Old 05-27-2013, 08:48 PM
billiemself77
Default How to do away with the anti-theft system
How can you remove a anti-theft system in a 1996 Ford Mustang 3.8 V6 automatic
mrappe
09-26-2015 10:16 AM
col2560
09-25-2015 08:59 PM
ShaneB26154
08-28-2015 04:47 PM
Stilz
08-18-2015 09:40 AM
Quick Reply: 3.8 V6 in a 1995 Ford Mustang
