Bucking under load.
Old 05-22-2013, 06:31 PM
JC316
JC316's Avatar
Default Bucking under load.
Hey guys, long time member of the 4.6l section, but I picked up an 00 mustang with the 3.8L engine. I know these motors fairly well from owning a 92 super coupe. I am having an issue with this car, it's bucking during acceleration. Doesn't matter how much gas I give it, it still bucks, once I am up to speed though, it stops. No bucking or misfire at idle or revving in park, only when it's under load.
No active codes and the only past code was for the PATS system, which I cleared and it never returned.
Checked the plugs, they are new. Gap was off, so I set it at .056. Wires are also new. I had a known working coil pack off from my old t-bird and tried it, no effect. Compression test was 165 PSI on every cylinder. Just picked up a new camshaft position sensor, no effect. When I changed it, I checked for play in the synchronizer and there was very little. MAF was clean. No vacuum leake
Next on my hit list is checking fuel pressure and making sure that the injectors are firing. Any other ideas?
JC316 is offline
Old 05-22-2013, 06:49 PM
3.8Cobra
3.8Cobra's Avatar
What kind of plugs do you have in? If they are Platinum, you never gap them, regardless what auto zone or anyone of them says. Aside that, you're having the same type of problem I'm having, and I have no idea aside a new coil pack.
3.8Cobra is offline
Old 05-22-2013, 06:51 PM
Toadster
Toadster's Avatar
our coil pack 'worked' but replacing it got rid of the hesitation - see my post
https://mustangforums.com/forum/v6-1...ast-night.html
Toadster is offline
Old 05-22-2013, 06:59 PM
JC316
JC316's Avatar
Champion copper plugs.
JC316 is offline
Old 05-22-2013, 08:57 PM
JC316
JC316's Avatar
Think I found the source. Hooked up a fuel pressure gauge to the valve. Key on, engine off, 40PSI. Engine running, it does this creepy little dance. Goes down to nearly 20 PSI and then jumps back up to 30PSI in rhythm, just like the rhythm of the engine bucking. Now, I have never dealt with an electronic FPR, but I can't see any situation where that would be normal. Unplug the FPR and it drops, blip the throttle wide open and it jumps to 60PSI, but at idle and part throttle, it dances.
JC316 is offline
Old 05-25-2013, 03:59 PM
JC316
JC316's Avatar
Got it. The fuel filter was badly clogged, not allowing enough pressure. That is what caused the dancing gauge and the misfire.
JC316 is offline
Old 05-25-2013, 11:01 PM
jthorn9
The Godfather
jthorn9's Avatar
Glad to see you found it!!!
jthorn9 is offline
mungodrums
10-07-2015 04:01 AM
Matt's 95 Stang
10-05-2015 07:16 AM
jstrothe
09-24-2015 12:17 PM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: Bucking under load.
