8.8 Pinion Shaft
Old 05-24-2013, 09:15 PM
ron.gcp
ron.gcp's Avatar
Default 8.8 Pinion Shaft
The pinion shaft on my rearend worked its way loose and got damaged. Is there somewhere to buy one or is this a salvage yard piece?
ron.gcp is offline
Old 05-24-2013, 09:43 PM
reldla1996
reldla1996's Avatar
You will need to replace both the ring and pinion gears.
reldla1996 is offline
Old 05-24-2013, 09:55 PM
explain damaged please. And did the big nut that holds the pinion in the housing come loose? I fear your gonna need more than just the pinion shaft.
Old 05-24-2013, 11:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
where in VA are you??
mjr46 is offline
Old 05-25-2013, 05:33 AM
ron.gcp
ron.gcp's Avatar
I got another limited slip unit, ring and pinion (3.73), and axles, but no pinion shaft. Was trying to figure out where I can get shaft and shaft lock bolt. Thanks for everyones reply.
ron.gcp is offline
Old 05-25-2013, 05:35 AM
ron.gcp
ron.gcp's Avatar
Hampton V.A., A few miles from V.A. Beach.
ron.gcp is offline
Old 05-25-2013, 06:34 AM
Is this what your looking for
http://www.ebay.com/itm/NOS-FORD-8-8-TRACTION-LOCK-DIFFERENTIAL-PINION-SHAFT-AND-PIN-E9AZ4211A-/330909293120?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0bbb1a40&vxp=mtr
Old 05-25-2013, 06:53 AM
this was a double post for some reason
Is there a way to delete posts or does a mod have to do it??
Last edited by dawson1112; 05-25-2013 at 06:55 AM. Reason: double post for some reason
Old 05-25-2013, 04:22 PM
ron.gcp
ron.gcp's Avatar
Originally Posted by dawson1112
Thanks. I just ordered one from Summitt for $14.95. I was just hoping to find one locally. The one I ordered wont be here untill June 3. Some how I sheared the bolt holding the pin in and the pin was slapping around. Messed the pinion gear teeth up where the pin was smacking it. Could of been worse if the pin would of came all the way out though.
ron.gcp is offline
Old 05-25-2013, 05:29 PM
That locking bolt must have had a defect in it or something cause they are hardened and I cant imagine putting enough force on one to shear it in two. Unless it didn't have any thread lock on it and it loosened up enough to hit .
Quick Reply: 8.8 Pinion Shaft
