68 front brakes
Old 06-05-2013, 12:15 PM
Roguedreams
Roguedreams's Avatar
Default 68 front brakes
Good day all,
Hi new user here and first post, just picked up a 68 conv with a straight 6. Have a question and forgive that I don't know the correct terms, had a leak in the front passage brake, took the hub off and the leak is in the wheel cylinder but the question is, there are no pins in the cylinder the pads go right into it, is this normal? Took the right side off also and no pins. This still has the original 9" hubs.
Thanks
Don
Roguedreams is offline
Old 06-22-2013, 03:02 PM
120mm
120mm's Avatar
If memory serve, yes, that's the way they are supposed to be. Did they function before you took them apart, besides the leak?
120mm is offline
10-07-2015 07:02 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
tj@steeda
Steeda Autosports
09-16-2015 07:53 PM
tj@steeda
Steeda Autosports
09-08-2015 11:50 AM
Quick Reply: 68 front brakes
