95 5.0 Wont Reverse
95 5.0 Wont Reverse
Hey guys, I just bought a 95 5.0, and after I get on it, it won't go in reverse. If I drive normally it shifts into reverse fine, but after I drive it like I stole it, its like reverse is neutral, the car won't move. Then after about an hour of sitting it will shift fine again.
I could have told you rebuild or replace..... Might as well flush and change filter and pray that helps, if not your replacing/rebuilding a tranny. I was just giving a suggestion. mjr46 is most likely right but I don't know how mechanically inclined you are. Had a friend replace everything injection and ignition related on a project car he couldn't get running. His tank was empty the whole time..... I can't assume through online that you would have thought to try what I said already.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
