Underdrive pulley question
Old 06-14-2013, 09:51 PM
Saabonthis
Saabonthis's Avatar
Default Underdrive pulley question
So my 03 gt has underdrive pulleys. I'm unsure on the brand, however,it's definitely not Steeda. Maybe BBK or SR Performance brand. Anyways, my question... The crank pulley has an extra pulley attached to it as if it were for an accessory. It's not used, so would a person be able to remove this without messing up any balancing issues? Only curious because that's a bit of rotational weight that I would assume isn't necessary. Sorry if this has been covered or seem like an amateur question. I'm not fully familiar with the pulley setup on these motors.
Saabonthis is offline
Old 06-14-2013, 10:15 PM
school boy
school boy's Avatar
you have the piggy back style under drive pulleys. It takes the factory balancer and sandwhiches the underdrive lower pulley between the crank and balancer. You cannot remove the balancer!
school boy is offline
Old 06-15-2013, 08:09 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
^+1, do NOT remove the harmonic balancer. Piggyback UDPs are a cheap kludge, something no serious enthusiast would use--get a proper set with an SFI rated replacement balancer...
cliffyk is offline
Old 06-15-2013, 09:51 PM
VistaBlueFrank68
VistaBlueFrank68's Avatar
Improper pulley size makes the fan and water pump turn too slow or too fast. Production water pumps are normally run at 20% over engine speed and do not perform well over 5000 engine rpm. Under-drive pulley's generally reduce water pump speed to 85% of engine rpm and may not provide enough water flow to cool the engine.
That's the Ford book answer, your car will thank you if you put a stock pulley on.
VistaBlueFrank68 is offline
Old 06-15-2013, 10:07 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
This ^ is true, however I have been running Steeda's UDPs here in Florida for 3-1/2 years and 85k miles, and have never had any cooling or charging (or AC) problems--FWIW here is an analysis I did of the of the ratios and accessory drive speeds "way back then":
cliffyk is offline
Old 06-16-2013, 12:54 AM
Sxynerd
Sxynerd's Avatar
For many it's an idea of $:Hp ratio.
I never went with the UDP's because the cost of a good set was about the same cost a weekend at the track learning to drive. ...never did figure that part out, lol.
Also, if you ever plan on going F/I, you'll need to take them off.
The slight return of lost Hp would be barely noticeable if you have other mods. I'd say save your ducks and get a good set of cams or something else.
..but that's just me spending your money. Post some pictures of your ride.
Sxynerd is offline
Old 06-17-2013, 09:33 PM
FormlessGT
FormlessGT's Avatar
I'd recommend keeping the stock alt pulley on. After about 4 months it would kill my brand new battery. I put the stock pulley on and it has been fine ever since.
FormlessGT is offline
Old 06-19-2013, 10:48 AM
moncherou
moncherou's Avatar
i did not have cooling issues with the steeda udp's i had prior to the blower. i'm in southern california and while humidity is low, it gets to 100+ in the summer time. that said, i think our temp guage sucks nongs because it once it warms up it stays in the same position as opposed to when i monitor with a tuner which reveals much more about the actual state of affairs
moncherou is offline
Old 06-25-2013, 03:36 PM
Saabonthis
Saabonthis's Avatar
I actually just ordered cams for it today. Hitech stage two. Love the sounds and have heard many positive things about Hitech. Plus they are only a few hours away from me.
Here are a couple pictures.
Found a black cobra at the track, so I had to park next to it
GimpyHSHS
19
12-19-2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
UrS4
09-30-2015 10:13 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Underdrive pulley question
