Intermittent electrical
Old 06-15-2013, 10:36 AM
PRANGERS
PRANGERS's Avatar
Default Intermittent electrical
Recently purchased a 1988 5.0 lx hatchback. Have been having problems with
the heater blower and blinkers working intermittently. One time they will work and then the next not. Can't seem to find the reason. Got any ideas. Also this
happens together, they either both work or both don't.
PRANGERS is offline
Old 06-15-2013, 05:34 PM
petrock
petrock's Avatar
Pick up the factory service manual for your year/model ride, or get a subscription to alldatadiy.com and check the wiring diagram. Most likely those two components share a common ground and that ground is loose/damaged/broken. Good luck...
petrock is offline
Old 06-15-2013, 08:12 PM
mattdel
mattdel's Avatar
No need to get one, I have a full shop subscription. They share no common wiring. Possibly a column problem, but there would likely be other systems affected.
mattdel is offline
Old 06-16-2013, 01:17 PM
PRANGERS
PRANGERS's Avatar
Thanks for the info. I have been doing a little more research and am
wondering if the ignition switch might be to blame. I am going to call a local
dealer to also see if this has been in for the recall. The past history of this car shows nine owners it is possible that it got over looked.
PRANGERS is offline
svfetter
10-05-2015 11:39 AM
LiquidDrink
09-29-2015 10:06 AM
mrappe
09-26-2015 10:16 AM
SteelerNation82
09-16-2015 07:11 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Intermittent electrical
