why would you unplug a map sensor?
Old 06-18-2013, 06:44 PM
duncan01
duncan01's Avatar
Default why would you unplug a map sensor?
my car is an 88 lx originally a speed density car converted to mass. Just noticed that the map sensor is unplugged. It appears there it no place to plug it in on this aftermarket intake. I guess my question is do I need it and will it hurt anything. Side effects?
thanks
duncan
duncan01 is offline
Old 06-18-2013, 07:56 PM
capri debris
capri debris's Avatar
What exactly is unplugged... the vacuum hose or the electrical connector?
A speed density M.A.P. (manifold absolute pressure) sensor will have a vacuum hose connected to the intake, because speed density is dependent on manifold vacuum to tell the ECU how far the throttle is opened and uses a pre-set table of how much air is entering the engine and adds fuel accordingly.
Mass air cars use the same sensor, but without a hose connected which essentially converts the M.A.P. sensor into a barometric pressure sensor that gauges atmospheric pressure so the ECU knows what altitude the vehicle is operating at and how dense the air charge is. The ECU knows how much volume of air is entering the engine by the mass air sensor and uses the "MAP" sensor to tell it exactly how dense that air happens to be.
So in other words, if the electrical connector is connected and the car has been converted to mass air, you shouldn't have a vacuum hose connected to the sensor.
capri debris is offline
Old 06-18-2013, 07:57 PM
Duncan_GT
Duncan_GT's Avatar
I may be wrong, but if its been converted from SD to a MAF setup, then there is no need for the MAP. It does, however, use the same sensor from what I've seen.
Edit - Capri beat me before I could edit.
Duncan_GT is offline
Old 06-18-2013, 08:15 PM
duncan01
duncan01's Avatar
Sorry fellas, I was in the garage and had a thought and just turned around and started typing it before using the one rule we should all know. Google!!
Two seconds after I posted it I found the answer. Sorry you took the time to respond thanks for the quick reply.
Wont happen again.
Duncan
duncan01 is offline
Old 06-18-2013, 08:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
map become a baro sensor and vaccum line is not connected to intake anymore/period
mjr46 is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Dathan
10-05-2015 05:52 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: why would you unplug a map sensor?
