dyno tune or bama tune?
Old 06-25-2013, 02:52 PM
dustya
dustya's Avatar
Default dyno tune or bama tune?
Want your opinion which 1 is cost effective? Dyno tune 500 with a handheld or 380 for a bama tuner? My mods coldair and hpipe thats all I plan to do.
dustya is offline
Old 06-25-2013, 03:44 PM
uberstang1
Chupacabra
uberstang1's Avatar
You dont even need a tune really, but dyno tune is always the best route. Your cold air intake doesn't do anything more than the factory cold air intake except dress up the engine bay.
uberstang1 is offline
Old 06-25-2013, 03:58 PM
Dragonus18
Dragonus18's Avatar
Uber is actually pretty spot on. I had one and all it does is make a suction sound when you give it some gas. Sounds nice but doesnt really do anything. Same goes for the h-pipe. You might see a little more power but otherwise the same applies.
Dragonus18 is offline
Old 06-25-2013, 04:05 PM
dustya
dustya's Avatar
So I should go with a dyno tune?
dustya is offline
Old 06-25-2013, 04:10 PM
Soldier GT
Soldier GT's Avatar
No not now. You need to add some more mods to get the full effect of the tune..
Soldier GT is offline
Old 06-25-2013, 04:12 PM
Subbz
Subbz's Avatar
I think they mean you're better off saving your money from getting either one since either of those mods don't really require tuning. But if you had to get your car tuned, dyno tunes are way better than a handheld tuner. Handheld tuners for the most part are basically cookie cutter tunes compared to dyno tunes where everything on your car is monitored and then they tune your car to exact specifications according to your car.
Subbz is offline
Old 06-25-2013, 04:13 PM
Soldier GT
Soldier GT's Avatar
Yep you got it..
Old 06-25-2013, 04:19 PM
Subbz
Subbz's Avatar
Originally Posted by Soldier GT
Yep you got it..
Thanks! And as Soldier said you need more mods to get the most out of a tune. And for the most part it seems that the only time you're forced to get a dyno tune is if you get a more aggressive cam or adding on F/I. Most bolt ons you can get away with just using a handheld tuner.
Subbz is offline
Old 06-25-2013, 08:40 PM
dustya
dustya's Avatar
thxs for info bein a convertible im not gonna go crazy with mods just wanted a little more power
dustya is offline
Old 06-26-2013, 05:59 AM
Soldier GT
Soldier GT's Avatar
Best bang for the buck would be some gears..
Quick Reply: dyno tune or bama tune?
