06 heater core
Old 06-25-2013, 11:21 PM
TheBiggestCat01
TheBiggestCat01's Avatar
Angry 06 heater core
I've been attempting to replace my heater core and so far it has been less than fun. I'd rather replace the engine again(I've done that). So far I'm just shy of pulling the entire dash its mostly unbolted and if it would've came out on the first couple of tugs it would be out. If anyone can she'd some light before I break out the sawsall I'd appreciate it.
TheBiggestCat01 is offline
Old 06-30-2013, 11:13 PM
flyhigh@mach1
flyhigh@mach1's Avatar
Have not done that work. Are you using any manuals? Let us know how it turns out.
flyhigh@mach1 is offline
Old 07-01-2013, 02:07 PM
Stang-aholic
Stang-aholic's Avatar
I havnt heard of this happening but Im sure someone around may know some more.
Stang-aholic is offline
Old 07-01-2013, 02:24 PM
http://iihs.net/fsm/?dir=461&viewfile=Instrument Panel.pdf
Review the diagrams and make sure it's all disconnected.
Heater cores are never fun. Did one way back in high school (shop) and never again. There are no easy ones either. All of the ones I know require removal of the dash...
You may have to disconnect the steering shaft if you haven't already? That is the one thing most people try to avoid doing.
Good luck.
Old 07-01-2013, 11:07 PM
TheBiggestCat01
Yep steering has to come out. Whole dash has to come out
Old 07-01-2013, 11:13 PM
TheBiggestCat01
If you're considering this you better be committed its not for the weak!�� part of any challenge is knowing the out come. So knowing that yes, you do have to completely remove the whole dash to access the unit should get you started in the right direction.
Old 07-22-2013, 01:50 AM
YoungBlood
YoungBlood's Avatar
Doing this on my Jeep right now... it sucks
YoungBlood is offline
djbigskrilla
09-20-2022 01:04 AM
mrtrodonet
09-19-2020 03:12 PM
Seanam
10-04-2015 10:15 AM
Calizic
08-28-2015 01:46 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: 06 heater core
