Passenger auto switch
Old 06-30-2013, 07:20 PM
mustang_gt808
mustang_gt808's Avatar
Default Passenger auto switch
Hey guys my automatic window passenger side don't go up by itself now I would have to hold the switch but my driver side works! Any idea
mustang_gt808 is offline
Old 06-30-2013, 07:49 PM
VistaBlueFrank68
VistaBlueFrank68's Avatar
/////////////////////////////// Anti-Moderator Reverse Flux Lock ////////////////////////////////
Does the passenger side switch auto actuate the window? If you push the button on the passenger side, does it auto up or down? If so you have a 1/2 bad switch on the driver side. Possibly coffee, sugar and cream. The passenger switch is closest and would take most of the spill. Would you be a lefty by any chance holding the cup over the arm rest?
If the car is an automatic, not having to shift would allow left handed coffee holding.
Way off topic but this happened to Rod Taylor in a movie about an airliner crash. Spilled coffee, you got it. Now you'll have no need for the National Transportation Safety Board (NTSB) to inspect the tragic crash I just averted.
You're welcome.
Last edited by VistaBlueFrank68; 06-30-2013 at 07:52 PM. Reason: Edit locks applies by NTSB, Fed. Statute 00000.0003J
VistaBlueFrank68 is offline
Old 06-30-2013, 07:59 PM
mustang_gt808
You're welcome.
The window goes down with the auto switch I don't have to hold it but going up I have to do
Old 06-30-2013, 08:15 PM
VistaBlueFrank68
Do the passenger side switches work both ways? If yes and the driver side switch is poo, then it's dry goo in the switch hoo. It's an older car, lots of coffee drink-in and a spill-in.
My work here is done.
Call the car detective, Frank VistaBlue and I'll make spurious and dubious guesses as to your car malfunctions.
Old 07-01-2013, 09:04 AM
Shotokan1509
Shotokan1509's Avatar
Sometimes mine will stop randomly, usually reset fixes
With windows up press the down button until the window retracts completely and hold for an extra 2 seconds. Then roll up and hold for an extra 2 seconds.
Shotokan1509 is offline
Old 07-01-2013, 09:22 AM
Nuke
Nuke's Avatar
+1 on trying the reset procedure found in the OM before replacing anything.
Nuke is offline
Old 07-01-2013, 05:50 PM
VistaBlueFrank68
It's in your owners manual. Reseting, re-calibrates the bottom drop level and the top set 1/2" drop when opening and closing the door. It doesn't get sticky out. So did the re-cal voodoo fix it?
mtgldr
02-03-2024 09:00 PM
DreadPirateRoberts
09-26-2015 02:11 PM
pimp2303
09-17-2015 08:45 PM
Colin Ringle
09-15-2015 09:27 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Passenger auto switch
