Interior Problems
Old 06-30-2013, 09:37 PM
Freshman4life05
Freshman4life05's Avatar
Default Interior Problems
Hello All,
Was wondering if any of you guys have had problems with the leather on both door panels peeling off? I have tried for the past few months to get it to stick back on, but after a week or two it falls back off. Does anyone have any suggestions on what to do to fix it? Also if any of you have taken it somewhere to get fixed what did you end up spending?
Thanks in advance!!
Freshman4life05 is offline
Old 06-30-2013, 09:46 PM
vbstang13
vbstang13's Avatar
I had the same problem a couple of years ago; check out the link it will help you.
https://mustangforums.com/forum/2005...gging-fix.html
vbstang13 is offline
Old 06-30-2013, 09:53 PM
Freshman4life05
Thanks for the quick response... I did a search, but apparently I did not use the right words... My only issue with this is I have already tried other things like super glue, and other adhesives, so I worry that this is no longer an option for me
Old 07-01-2013, 09:28 AM
Nuke
Nuke's Avatar
The repair described in the link has worked for quite a few folks. Just follow the directions. If it doesn't hold, you either didn't follow directions or you have contaminated the surface(s) previously and the correct adhesive (NOT superglue) may not hold properly.
Nuke is offline
Old 07-01-2013, 09:16 PM
JCON
JCON's Avatar
Originally Posted by Freshman4life05
Hello All,
Thanks in advance!!
I actually just fixed mine tonight with a can of 3M 90 spray adhesive
I used one of these to flatten bubbles and push the edges back in their spot:
Yes you probably have one of these for dishes.
Be sure to let it sit at least an hour in a non-humid area and level. Good ingredients for success.
JCON is offline
Old 07-07-2013, 09:32 PM
Freshman4life05
JCON I know you only did this a few days ago but how well is it holding up? I just bought some of that weldwood stuff mentioned in that repair, but haven't had time to do it yet.... I have tried numerous adhesives and they hold up for a week or so and then it starts falling off again
Old 07-07-2013, 09:45 PM
Tubra
Tubra's Avatar
When I had my 06 I actually put vinyl with the diamond-punch pattern from a roll I ordered. I used 3M 90 Adhesive, and it held up for several years in the hot desert sun. The trick is to spray a good even layer and let both sides dry a bit according to the instructions. That's the important part... LET IT SIT a bit.
http://solutions.3m.com/wps/portal/3...=1114284885132
Tubra is offline
Old 07-07-2013, 09:50 PM
Freshman4life05
Thanks Tubra & JCON I will have to give that a shot and see how that works
Old 07-07-2013, 09:53 PM
Tubra
Tubra's Avatar
Just make sure to use the 3M 90, but be careful, it's stickier than the slit in my nerf turbo football from my teen years...
Tubra is offline
Old 07-07-2013, 10:21 PM
Freshman4life05
HAHAHA!!!! Yea the last thing I tried was something very similar to the 3m stuff.. i got it from autozone and it is supposed to be for headliner, carpet, etc so I thought that should work pretty well and it did for about a week... the drivers side is not bad at all... the passenger side is horrible
Quick Reply: Interior Problems
