Spark knock, no power.
Old 07-02-2013, 08:04 AM
99gt302
99gt302's Avatar
Default Spark knock, no power.
Ok, so I have a 2007 Mustang Gt.
Mods: Hot Rod Cams, Pacesetter Long Tubes, JLT CAI (110mm)
I have a SCT canned tune, but I doubt that's the problem as it was fine before.
The car used to run fine, then one day the o2 sensor went out, I made some extensions and got one a little too short(still connected fine, just a little tight), so I'm thinking that it may have pulled out or something and causing the issue. However, there is no check engine light?
What are some other things to check for? I have replaced plugs & fuel filter.
Could it be bad Coil on Plugs?
I sodered my connections on the O2s.
When I am driving, it just feels like it has no power, and when I shift gears into like third it will spark knock for a second. Sometimes I hit the gas (moderate throttle) and i can feel it actually stop making power, like I am hitting the brake.
Thanks!
99gt302 is offline
Old 07-02-2013, 08:06 AM
99gt302
99gt302's Avatar
Forgot to mention, it skips a little too when It is not warmed up.... overall just running horribly.
99gt302 is offline
Old 07-02-2013, 08:29 AM
tbar
tbar's Avatar
Maybe fuel pump or you got some bad gas.
tbar is offline
Old 07-02-2013, 08:32 AM
99gt302
99gt302's Avatar
^ No bad gas, been happening too long and I get gas from all around. How can I check fuel pump, I though about that too.
99gt302 is offline
Old 07-02-2013, 08:48 AM
tbar
tbar's Avatar
Check the fuel pressure at the fuel rail.
tbar is offline
Old 07-03-2013, 09:08 AM
Simon1
Simon1's Avatar
A data log by a good tuner will tell you if the O2s are working. If you have aftermarket coils, go back to stock. I would diagnose the problem to a particular spot before buying or throwing parts at it.
Simon1 is offline
Old 07-03-2013, 09:09 AM
Simon1
Simon1's Avatar
Any engine codes?
Simon1 is offline
Old 07-03-2013, 11:26 AM
red96v6
red96v6's Avatar
SCT canned tune can compensate for Hot Rod Cams, Pacesetter Long Tubes, JLT CAI (110mm)??
I always thought the generic preloaded tunes were only good for stock cars.
red96v6 is offline
Old 07-03-2013, 07:42 PM
hammeron
hammeron's Avatar
Check for vacuum leaks in the air intake system, unmetered air might be causing the pinging. If your handheld tuner allows, you can remove some timing until you determine the issue.
hammeron is offline
Old 07-17-2013, 02:31 PM
99gt302
99gt302's Avatar
Today I drove the car and it is still acting up. After idle at a stop light and take off it pops through the intake, any suggestions
99gt302 is offline
Quick Reply: Spark knock, no power.
