Barn find '72 Mach 1
Old 07-07-2013, 03:19 AM
steliosthem
steliosthem's Avatar
Default Barn find '72 Mach 1
Judging from your experience, can this engine be saved or is it a lost cause?
http://www.car.gr/classifieds/cars/photos/3676894/
steliosthem is offline
Old 07-07-2013, 10:08 AM
Waffles
Waffles's Avatar
Location: Detroit; where the weak are killed and eaten.
Waffles is offline
Old 07-07-2013, 10:17 AM
LynnBob Mustang
LynnBob Mustang's Avatar
Depending on how deep your pockets are and what your abilities are anything can be fixed.
That may beyond most novice backyard restorers around here.
Lynn
LynnBob Mustang is offline
Old 07-07-2013, 11:08 AM
jimkaray
jimkaray's Avatar
If the engine is seized up then it probably isn't worth salvaging. If it will rotate that's a good sign. Then you can hook a battery to it and at least crank it over and do a compression check on each cylinder. Check the VIN for the engine code to see if its an original 4 bbl car. The 5th digit should be either a Q or an R code if its the 4bbl Cleveland and desirable for collectors so it might be worth something in parts alone, assuming nothing is cracked or otherwise broken.
jimkaray is offline
Old 07-07-2013, 01:21 PM
steliosthem
Yes it states it is Cleveland. Thank you for your answers. I'll post again if I make the move :-).
Old 07-07-2013, 04:58 PM
lucasp
lucasp's Avatar
how good are you with tools?
lucasp is offline
Old 07-07-2013, 06:32 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
How long has it been sitting out in the rain without a hood?
fastbackford351 is offline
Old 07-07-2013, 10:27 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i cant get the link to work for me..but if the engine is seized you might just be able to pour some marvel mystery oil down the spark plug holes and let it sit for a week it might free up
rmodel65 is offline
Old 07-07-2013, 10:34 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
also that is like a 650-800 US dollar car at the most...
rmodel65 is offline
Old 07-08-2013, 08:17 AM
120mm
120mm's Avatar
I doubt '72 Mach 1s are a common car in Greece. It would definitely be a labor of love.
The great things about these cars is that anything, and I mean anything is rebuildable. All it takes is money.
That engine would need to be completely redone.
120mm is offline
Quick Reply: Barn find '72 Mach 1
