side molding
Old 07-07-2013, 08:29 AM
beeker
beeker's Avatar
Default side molding
What is the best method for removing the molding on the middle of the doors on a new edge ?
beeker is offline
Old 07-07-2013, 09:28 AM
NYstang
MF Staff Snitch
NYstang's Avatar
1- wait for a hot day
2- find the following: fishing line, some sort of lube, and towel (for wiping lube), and a heat gun or hairdryer in a pinch. and googone.
3- heat molding
4- spray a bit of lube along top of molding so it soaks the 3M **** under it
5- slowly rubn fishing line behind molding, pulling it out and back (or forward), SLOWLY
6- molding off
7- use goo gone to get rid of excess tape
8- rewax door
your paint may be slightly mismatched where the molding is due to sun exposure, so keep that in mind. Mine wasnt after 5 years, but every car is different. Also, go slow because I have seen a couple cases where the paint was ripped off the door by going to fast, or using too much force.
NYstang is offline
Old 07-07-2013, 09:57 AM
DRAGUL
DRAGUL's Avatar
After being on there for 14 years I would suspect you are going to end up with a ghost stripe on both doors.
DRAGUL is offline
Old 07-07-2013, 11:33 AM
beeker
beeker's Avatar
If that is the case maybe I should leave them on for now.
beeker is offline
chrisdbassplayer
10-13-2015 06:53 PM
b8checker
10-08-2015 12:55 PM
jrrhd73must
10-02-2015 09:17 PM
ChampInSD
10-02-2015 04:55 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: side molding
